nu0 parameter of Herschel Bulkley viscosity model |
December 4, 2020, 07:37 |
Liliana de Luca Xavier Augusto
Rep Power: 13 |
Dear all,
I am trying to use the Herschel Bulkley viscosity model in a flow between plates, very simple. However, I am not getting how should I set a value for "nu0" in transportProperties files. I understood that it should be a high value in order to represent a high viscosity at very low shear rates. However, when I change this value, the velocity profile algo changes. Does anyone know a way to estimate this parameter? Thanks! |
July 29, 2021, 23:04 |
mohammad
Rep Power: 11 |
Hi liliana,
Did you find any solution for this problem? |
Viscosity model - error: object is not allocated - C++ beginner | avila.vc | OpenFOAM Programming & Development | 5 | February 14, 2022 02:00 |
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
What viscosity to use for solid phase in VOF model | redwanamit034 | FLUENT | 0 | June 14, 2017 17:09 |
Fluid turns into solid at given T (via viscosity UDF or solidifcation model?) | jpina | FLUENT | 1 | April 3, 2016 03:48 |
