Foam_user_libbin
Like Tree1Likes
  • 1 Post By chegdan
Old   November 26, 2013, 10:13
Default Foam_user_libbin
Salam Hassan
Salam-H is on a distinguished road
HI every one. I am trying to find $FOAM_USER_LIBBIN on my computer, I dont know where it is, I have checked every where. I think when I installed OpenFOAM this folder had been missed, I reinstalled OF many times and yet cannot find the folder. Any suggestions please?
Thank you for you help in advance.
Salam
Salam-H is offline   Reply With Quote
Old   November 26, 2013, 13:58
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
if your OpenFOAM installation is installed correctly, go to your terminal and type
echo $FOAM_USER_LIBBIN
to go there, use
cd $FOAM_USER_LIBBIN
if OpenFOAM is not installed correctly....then you have more problems.
babakflame likes this.
chegdan is offline   Reply With Quote
Old   November 26, 2013, 14:07
Salam Hassan
to go there, use
Hello there,
Thanks a lot for replying, I have done exactly what you have suggested , it seems like I do have the folder. However when I try to run a blockMesh, I get an error which I dont know how to fix it, I thought it might be due to the lack of lib but I can see that I have it. Do you think if I send you the error , you have time to help me please? I really need some help please.
regards,
salam
Old   November 26, 2013, 14:23
Daniel P. Combest
Without more information i really can't help you. Have a look through
http://www.cfd-online.com/Forums/ope...-get-help.html
And then try to be more descriptive with your question and then i bet more people will help you and get you moving forward.
Old   November 26, 2013, 14:37
Salam Hassan
Hi again, I home I am not bothering you a lot. I truely appreciate your help. I have modelled a case, where I have water in a funnel, the water has to flow out from the funnel. In real life , it takes about 26 seconds for the volume of water to leave the funnel. However when I tried in Openfoam every thing seemed to be fine apart form plotting graphs, such as Alpha1 (VOF ) against Actual time, I tried and I couldn't find the way of doing it. Then suddenly I found a tutorial online, which does exactly what I want, but using Swak4Foam rather than ParaFoam, and I am trying to model the same case but I get error message from the first step, I have attached the error message to this quote and the case which I am trying to run can be found in the following link :
https://www.hpc.ntnu.no/display/hpc/...Postprocessing
I did install swak4foam and all the necessary files I believe.
I would be forever grateful for any help .
Best regards
Salam
Old   November 26, 2013, 14:41
Salam Hassan
Best regards
Salam
I uploaded a wrong file in the previous quote, this is the error message.
Old   November 26, 2013, 14:44
Daniel P. Combest
all warnings. did it not create a mesh?
Old   November 26, 2013, 14:55
Salam Hassan
It did create a Mesh but, I get the error messages, when I do setFields it still goes trough however with error messages again , and finally it cant be decompose it.
regards,
salam
Old   November 26, 2013, 14:58
Daniel P. Combest
regards,
salam
What are these error messages that you are getting? I can't go back and forth on this all day...so lets try to get this answered by providing a complete description of the problem and what exactly (not vaguely) you are experiencing.
Old   November 26, 2013, 15:11
Salam Hassan
I think I have attached the error message to the previous quote . and I have given the description of the problem, I have provided a link, the case I want to run can be found in the link.
I attached the error message to this quote so you dont have to go back up and look for it, and the link is :
in the link there is a tutorial, all the files are provided and I want to run the tutorial, because my case is very similar to it, but I get error messages.
The only reason I want to run this tutorial is to plot a graph similar to the one that can be seen in the provided link.
Best regards,
Old   November 26, 2013, 15:14
Daniel P. Combest
Read your attachment carefully, its full of warnings and not errors. I suggest you think about what you want to ask, compose a very thorough description of your issue and open a new thread. you may want to open a thread in the subforum for running and solving cases located at
http://www.cfd-online.com/Forums/openfoam-solving/
Good luck!
Old   November 26, 2013, 15:18
Salam Hassan
Good luck!
Ok , thanks a lot for your help, sorry for taking your time, and honestly even though I couldnt fix my problem but I learnt something useful from you, thank you again.
best regards,
salam
Old   November 26, 2013, 16:04
Salam Hassan
best regards,
salam
Hello again
I have just opened a new thread as you suggested , it can be accessed in the following link, if you are willing to help more please have a look at it.
Best regards,
Salam
Old   November 26, 2013, 16:28
Salam Hassan
Hello again
Best regards,
Salam
The link to the new thread is : http://www.cfd-online.com/Forums/ope...-warnings.html
Cheers,
Salam
