FSI solver for openFoam 1.6 ext
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 13, 2012, 11:11
Cool FSI solver for openFoam 1.6 ext
Stefano
Whyman is on a distinguished road
Hi everybody!!!
I'm trying to use the icoFsiFoam solver for openFoam 1.6 extended. I need to perform FSI problems.
The only thing is that i have a huge mesh and i need to run in parallel. Does anyone know how to compile icoFsiFoam in parallel?
Is there any similar solver for openFoam 1.70?
Please, help me!
Thank you
Stefano
Whyman is offline   Reply With Quote
Old   June 13, 2012, 16:47
Retired Super Moderator
Bruno Santos
Greetings Stefano,
Compile? Do you mean run it in parallel?
Have you learned first how to run OpenFOAM solvers in parallel? If not, first check the User Guide: http://www.openfoam.org/docs/user/da...x7-610002.3.11 - well, you might want to start this tutorial from the beginning first: http://www.openfoam.org/docs/user/damBreak.php
Not that I know of. If I'm not mistaken, FSI usually requires FEM to solve the solid part... but I could be wrong.
Although, I very vaguely remember about something similar for the official OpenFOAM... but I can't remember what it was
Wait... I knew I had read something about this, but apparently I got it the way around: http://www.cfd-online.com/Forums/ope...-parallel.html
edit: I forgot to mention that I re-found this particular thread by googling for "OpenFOAM FSI parallel"...
Good luck! Best regards,
Bruno
Old   April 29, 2013, 07:34
Default How to analysis FSI in OpenFoam?
rolix is on a distinguished road
hi
I want to analysis FSI problem by openfoam but i dont know what do i do?please give me a sample to analysis a problem and learn that process.
rolix is offline   Reply With Quote
Old   September 21, 2013, 12:46
Bruno Santos
Greetings rolix,
Sorry, I didn't see your message back in April of this year
I got the private message you sent me, but I'll answer here, since this way others can find the answer useful as well.
AFAIK, FSI is currently only present in Extend's variant OpenFOAM 1.6-ext and isn't present in the official OpenFOAM 2.x series.
You can install 1.6-ext by following the instructions available here: http://openfoamwiki.net/index.php/In...enFOAM-1.6-ext
As for FSI tutorials, check the tutorial "stressAnalysis/icoFsiFoam/flappingConsoleSmall".
In addition, you might want to have a look into this thread (it's already a long thread, so you might want to read it all first): http://www.cfd-online.com/Forums/ope...am-extend.html
Best regards,
Bruno
Old   October 26, 2013, 06:11
Bruno Santos
Hi rolix,
Since you decided to ask me in private once again, I decided to reply to you here instead
As I wrote a month ago in the previous post, the solver icoFsiFoam is only present in 1.6-ext. And it is not compatible with OpenFOAM 2.0.1, because 1.6-ext is very different from 2.0.1.
Nonetheless, you can try Philip Cardiff's "solidMechanics" toolkit for OpenFOAM, as explained here: http://www.cfd-online.com/Forums/ope...tml#post432903 - post #69
You can find simpler instructions for OpenFOAM 2.0.x here: https://github.com/wyldckat/solidMechanics/tree/OF20x
Best regards,
Bruno
hamsteri15 likes this.
icofsifoam
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
interfacing a fluid solver with abaqus Tuhin Rakshit Main CFD Forum 0 June 16, 2005 10:03
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 16:25
Error during Solver cfd guy CFX 4 May 8, 2001 06:04
