coeff of drag and lift on cylinder
Like Tree1Likes
  • 1 Post By niaz
Old   June 14, 2012, 10:21
Default coeff of drag and lift on cylinder
Malhar Malushte
malhar is on a distinguished road
hello everyone,
i am trying to study the flow across the stationary. rotating, osillating cylinder in a confined channel. i have simulated some flows. i am trying to calculate the drag and lift forces and their coeffs on the cylinder. i got values for Cd, Cl., but Cl seems to be constant for each time step, whereas the force is fluctuating w.r.t to vortex shedding.
please help me through this.
thanks n regards,
Malhar.
malhar is offline   Reply With Quote
Old   June 14, 2012, 11:38
niaz's Avatar
A_R
niaz is on a distinguished road
Dear Malhar
try to see only cl in your visualizer. because it maybe have small fluctuations in comparing to cd.
niaz is offline   Reply With Quote
Old   June 14, 2012, 12:22
Default ..
Malhar Malushte
dear Niaz,
thanks for replying...
well i am new to of. dont even know wat a visualizer is!
and if the values are seen for non rotating cylinder at Re=100, the Cl varies from -0.39 to -0.42. correct me if am wrong in next stmt. if the lift forces fluctuate w.r.t to vortex sheds, once +ve n once _ve in cylce den should nt the Cl also be +ve and -ve???
dat is my big worry.. Cl is constantly -ve varying from -0.39 to -0.42
pls guide me..
thanks n regards,
malhar
Old   June 14, 2012, 15:34
niaz's Avatar
A_R
Dear Malhar
visualizer is soft such as tecplot.
now, ofcourse it is not correct. it seems that your solution is not converged(it happens when you import mesh from another mesh generator such as gambit)
just in fvsolution increase the ncorrectors to correct it.
you can load your test case if you need more info.
Old   June 15, 2012, 01:27
Malhar Malushte
Dear Niaz,
once again thanks for the reply. solution not converged means do you want to say that my mesh is coarse??? or it has not reached a steady state???
what does increasing ncorrectors in fvsolution mean ??? i try going in the fvsolution directory.
pls tel me any way for understanding the codes in OF and its structure.
also i wil post here the control dict i have included in mycase.
thanks n regards,
malhar.
Old   June 15, 2012, 01:35
Default controldict
Malhar Malushte
| \\ / O peration | Version: 2.1.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application icoFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 200;
deltaT 0.01;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
functions
forces
type forces;
functionObjectLibs ("libforces.so");
patches (cylinder);
pName p;
UName U;
rhoName rhoInf;
rhoInf 1000; // Reference density, fluid
CofR (-2.5 0 0); // Origin for moment calculations
outputControl timeStep;
outputInterval 50;
forceCoeffs
type forceCoeffs;
patches (cylinder);
// pName p;
// UName U;
rhoName rhoInf;
rhoInf 1000;
CofR (-2.5 0 0);
liftDir (-2.5 0.5 0);
dragDir (-2 0 0);
pitchAxis (-2.5 0 0);
magUInf 1; // Free stream velocity
lRef 1; // Diameter of cylinder?
Aref 3.142; // Ref. Area = cross sectional area?
outputInterval 50;
Old   February 11, 2014, 10:35
ok
Maimouna is on a distinguished road
Dear Malhar,
did you fix your problem?
I'm working in something which is very close to your case.
If you get your result, could you please provide me all steps that you did.
I mean, what solver you used? What is blockMeshDict, controlDict, and all important files that you made changes on them?
Many thanks for your help.
Maimouna is offline   Reply With Quote
Old   May 28, 2014, 04:14
Default forcesCoeffs around a circular cylinder
Alireza Heidari
alirezahd is on a distinguished road
Hello dear Foamers
i'm new to openFoam and trying to calculate lift and drag coeffs around a fixed circular cylinder using codes in controlDict, i attain different result for a specific Re number (Re=200) when i change the diameter of the cylinder...
solver: icoFoam
first case: d=0.025 u=0.008032 nu=1.004*10^-6 ===> Re=200
second case: d=0.0375 u=0.005355 nu=1.004*10^-6 ===> Re=200
for the first case the lift coeffs amplitude is (-1.3 - 1.3) for the second one is between (-0.57 - 0.57) while according to papers it should be between (-0.7 - 0.7)
thanks and regards
Alireza Heidari
alirezahd is offline   Reply With Quote
Old   May 28, 2014, 06:31
Post lift and drage problem
niaz's Avatar
A_R
Originally Posted by alirezahd View Post
Hello dear Foamers
solver: icoFoam
thanks and regards
Alireza Heidari
Dear Alireza
plz copy your control dict to post. your problem is maybe in control dict firstly
alirezahd likes this.
Old   May 28, 2014, 07:24
Alireza Heidari
Originally Posted by niaz View Post
Dear Alireza
dear niaz
thank you so much for your instant reply
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
FoamFile
version 2.0;
format ascii;
class dictionary;
object controlDict;
startFrom latestTime;
startTime 0;
stopAt endTime;
endTime 600;
deltaT 0.02;
writeInterval 100;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
functions
forces
type forces;
enabled true;
functionObjectLibs ("libforces.so"); //Lib to load
patches ("cylinder"); // change to your patch name
pName p;
UName U;
rhoName rhoInf;
rhoInf 1.0; //Reference density for fluid
CofR (0 0 0); //Origin for moment calculations
outputInterval 5;
forceCoeffs
type forceCoeffs;
enabled true;
patches ("cylinder"); //change to your patch name
pName p;
UName U;
rhoName rhoInf;
rhoInf 997;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 0);
magUInf 0.006;
lRef 0.024186;
Aref 0.000906975;
outputInterval 5;
Old   May 28, 2014, 07:37
Alireza Heidari
Dear Alireza
OMG i undrestand my big mistake, i didn't change the magUinfo and yes it is the problem thank u so much
Old   June 30, 2014, 13:23
Default Problems getting Forces folder
  #12
JUAN DAVID OSORIO
jdosorio is on a distinguished road
Hello everyone,
I'm trying to calculate the forces on a complex mesh (corals), however the only folder that I'm getting is for forceCoeffs.
This is the ContolDict file. Am I doing somethign wrong?
Best regards,
Juan David
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application waveFoam;
startTime 0;
stopAt endTime;
endTime 20;
deltaT 0.001;
writeControl adjustableRunTime;
writeInterval 0.01;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
timeFormat general;
timePrecision 6;
adjustTimeStep yes;
maxCo 0.8;
maxAlphaCo 0.8;
maxDeltaT 0.001;
libs
"libOpenFOAM.so"
"libincompressibleRASModels.so"
"libfvMotionSolvers.so"
"libforces.so"
functions
forces //nombre que sea, se puede copiar varias veces
type forces;
outputControl timeStep; // runTime
outputInterval 1; // 0.01
patches ("palmata_ExportedfromBlender");
pName p; //could be p or p_rgh
UName U;
rhoName rhoInf;
log true;
CofR (0 0 -0.03);
rhoInf 1000;
forceCoeffs
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputInterval 1;
patches ( "palmata_ExportedfromBlender" );
pName p;
UName U;
rhoName rhoInf;
log true;
liftDir (0 0 1);
dragDir (1 0 0);
CofR (0 0 -0.052); //Axle midpoint on ground
pitchAxis (0 1 0); //Pitch axis for moment
magUInf 1;
rhoInf 1000;
lRef 1; //reference length scale for moment calculations (non-dimensional forces with 0.5rhoU2ArefLRef)
Aref 1; //reference length scale for moment calculations (non-dimensional forces with 0.5rhoU2Aref)
jdosorio is offline   Reply With Quote
cylinder, drag, lift, openfoam 2.1.0
Lift, drag and momentum coeff??? inginer OpenFOAM 1 December 7, 2010 11:42
Coefficient DRAG and LIFT - Cylinder 3D Jwolf CFX 11 February 4, 2010 05:08
Drag and lift Coeff Johari Gregorio FLUENT 0 December 3, 2006 18:31
Drag and Lift in 3D flow around a cylinder... Renato N. Elias Main CFD Forum 16 October 4, 2005 11:32
drag and lift coefficient of compressible cylinder Bin Li Main CFD Forum 1 March 7, 2004 09:49
