Server-installation: how to compile a new solver?
Like Tree1Likes
  • 1 Post By wyldckat
Old   June 25, 2012, 08:54
Default Server-installation: how to compile a new solver?
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I am trying to compile a new solver on a server version of OF.
What I would like to know is if I can follow this wiki-page, or not.
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   June 25, 2012, 13:22
Nima Samkhaniani
nimasam is on a distinguished road
read user guide carefully everything about compile a new solver or new library is there!
however it is as easy as :
1) go to solver folder which contains solver.C
2) prepare "Make" folder which contains two files
3) use command: "wmake"
nimasam is offline   Reply With Quote
Old   June 25, 2012, 17:45
Retired Super Moderator
Bruno Santos
Greetings to all!
To complement Nima's answer, here are the key references to keep in mind:
  • The environment variables "FOAM_USER_APPBIN" and "FOAM_USER_LIBBIN" define where to place the personal applications and libraries. This is the default user-side usage contemplated by OpenFOAM, where the user creates his/her own solvers/libraries, without contaminating OpenFOAM's core code.
  • To see where they point to:
    echo $FOAM_USER_APPBIN
    echo $FOAM_USER_LIBBIN
  • When using a server installation, there is a possibility that you want to actually use a cluster system. In this case, it means that those folders should also be somehow visible on the cluster's machines. If not, you're going to have to send them along with your simulation case.
  • If you copy-paste an already existing OpenFOAM solver and/or library code for modifying, do not forget that it is by default set to use these variables:
    echo $FOAM_APPBIN
    echo $FOAM_LIBBIN
    This is why the USER ones exist
Best regards,
Bruno
Luttappy likes this.
Old   June 27, 2012, 06:31
Samuele Z
It's exactely like to compile it on my desktop.
That's great.
Thanks a lot,
SamIam
How to compile a new solver in OpenFOAM-2.1.0? sandy OpenFOAM Programming & Development 24 July 27, 2016 04:10
Working directory via command line Luiz CFX 4 March 6, 2011 20:02
How to compile an unsteady solver based on solver of MRFSimpleFoam? renyun0511 OpenFOAM Running, Solving & CFD 0 April 27, 2010 11:16
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 14:08
Compile new solver under SuSE 64bit OS hsieh OpenFOAM Running, Solving & CFD 3 September 8, 2005 11:56
