September 28, 2012, 02:22 |
calculating problem in a 3D case
sqing
Rep Power: 13 |
I'm a new Foamer, I want to calculate a 3D case using rhoPimpleFoam solver, but there is something wrong that I can't deal —— Starting time loop Reading/calculating field UMean Reading/calculating field pMean Reading/calculating field UPrime2Mean new cannot satisfy memory request. This does not necessarily mean you have run out of virtual memory. It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library Thanks! |
axisymmetric wedge case problem | comedy_tigers88 | OpenFOAM Running, Solving & CFD | 0 | June 16, 2012 04:45 |
Problem with axi-symmetric case using sonicFoam | Madhura | OpenFOAM | 0 | April 16, 2010 16:59 |
problem when I run the case | Rui | Siemens | 1 | February 1, 2007 06:25 |
case example for HVAC problem | kevin | FLUENT | 0 | April 3, 2004 12:09 |
Problem in calculating drag coefficient | Sohail Ahmed | FLUENT | 2 | March 18, 2004 00:40 |
