unsteady state to steady state
Old   October 31, 2012, 03:11
Default unsteady state to steady state
neetu kumari
neetu kumari is on a distinguished road
Hello to all!
I am using twoLiquidMixingFoam solver of OpenFoam v-2.0.1. This solver is originally for unsteady state simulations. But, I want to use it for steady state simulation. Here, my questions are: whether it is possible to use an unsteady state solver to steady state or not? If possible, then how should i implement the solver code to steady state simulations?
If any one knows the answer of these questions please reply me as soon as possible.
Thank you
neetu kumari is offline   Reply With Quote
Old   October 31, 2012, 06:53
Jon Elvar Wallevik
JonW will become famous soon enough
Hi there, Neetu
I have not used twoLiquidMixingFoam, but I have done this for interFoam, with success (i.e. analytical solution and interFoam show the same result). However, the only downside is much longer computational time needed. There is a special time independent interFoam (don't remember the name) which is much much faster.
If you do this, I recommend reduce your time step and Co number in controlDict, to maintain stability, as well as reduce the tolerance values in fvSolution.
The best approach is if you have any simple analytical case in which you can benchmark your time independent approach.
Jon
JonW is offline   Reply With Quote
Old   June 9, 2016, 13:29
Rimsha
block is on a distinguished road
Originally Posted by JonW View Post
Hi there, Neetu
Jon
Hi Jon,
I am also interested in turning interFoam into steady state solver, isit possible for you to help by briefly outlining how you implemented this.
Kind Regards
Rimsha
block is offline   Reply With Quote
Old   June 14, 2016, 11:26
Default LTSInterFoam
Jon Elvar Wallevik
Hi Rimsha
sorry for the late reply, ... was off from work
For interFoam, there is a steady state alternative called LTSInterFoam
If memory serves me right, then it was first implemented in the OF 2.0,
(is at least still available in 2.3.1).
Use that solver, and check the tutorials folder for examples
/home/your username/OpenFOAM-2.3.1/tutorials/multiphase/LTSInterFoam
Cheers
Jon
Old   June 14, 2016, 18:16
Rimsha
Hiya,
Thanks a lot for the reply Jon, highly appreciate it, i will look into the solver and tutorials.
Kind Regards
Rimsha
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
is there any Differnce between results of Steady state and unsteady state sreenivas FLUENT 0 February 20, 2012 10:13
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
question about steady state& unsteady state particle liuyuxuan Main CFD Forum 0 February 26, 2010 09:19
