November 17, 2012, 06:19 |
Taylor microscale
Mahdi Hosseinali
Rep Power: 18 |
has anyone calculated taylor microscale in openfoam?
Appreciate it if you share the code. |
November 20, 2012, 06:33 |
Mahdi Hosseinali
Rep Power: 18 |
any one has any Idea?
November 20, 2012, 12:16 |
Daniel P. Combest
People might be more likely to help if you provide a little more information e.g. equations; sources; what you have tried already; what type of simulation your are performing. I'm interested in the topic if you can provide more details.
Last edited by chegdan; November 21, 2012 at 07:54. Reason: edit: this sounds better |
December 7, 2012, 05:28 |
Mahdi Hosseinali
Rep Power: 18 |
thanks for the interest chegdan,
Taylor microscale is the main length scale measured in turbulent homogeneous box to determine Reynolds number since there is no physical length scale. here is a more descriptive of what it naturally is: http://en.wikipedia.org/wiki/Taylor_microscale but a formula to calculate it is presented in "turbulent flow" by Pope in page 199. Can you tell me how to put that formula in Opefoam? |
December 10, 2012, 14:50 |
Daniel P. Combest
Looking at Pope, around the page that you suggested, I find that the longitudinal Taylor microscale can be related to the transverse Taylor microscale via
where However, this formulation seems simplistic compared to the definition by pope using the longitudinal () and transverse () autocorrelation functions. If you are looking for those, then I will have to think about this some more. If you are satisfied with the second equation formulation, then I would suggest you look into the post-processing utilities as to how variables are read in at each time and used to calculate what you want e.g. Co utility. Give it a try and post back if you run into problems. |
