Keep sets when mergeMeshes
Old   December 30, 2012, 11:48
Default Keep sets when mergeMeshes
Florian
Horus is on a distinguished road
I've two meshes which were created using fluentMeshToFoam -writeSets -writeZones. These meshes are merged using mergeMeshed -overwrite.
The original meshes contain zone and set information, however in the merged mesh this is lost.
Is there any way to keep / recreate zones/sets? My goal is to use tools like mergeOrSplitBaffles and at the end dynamicMeshMotion with AMI.
Thanks!
Horus is offline   Reply With Quote
Old   January 2, 2013, 06:51
Florian
I've found this bug report regarding the issue: http://www.openfoam.org/mantisbt/view.php?id=432
However, it should be fixed in 2.1.x. Anybody could confirm that? I try with 2.1.1 and it does not seem to work.
MergeMeshes with version OF14 jens_klostermann OpenFOAM Bugs 2 November 7, 2014 16:27
[mesh manipulation] MergeMeshes hsieh OpenFOAM Meshing & Mesh Conversion 3 September 10, 2014 09:15
[ICEM] Exporting node sets from ICEM CFD automation ANSYS Meshing & Geometry 1 September 7, 2012 14:47
[mesh manipulation] MergeMeshes and stitchMesh problem flo OpenFOAM Meshing & Mesh Conversion 6 May 10, 2010 10:40
[Technical] Definition of mesh sets chbenz OpenFOAM Meshing & Mesh Conversion 0 April 7, 2009 10:00
