DirectMapped in FSI problems
Old   April 2, 2012, 14:16
Default DirectMapped in FSI problems
Santiago
gascortado is on a distinguished road
Hi, I'm trying to model a fluid structure interaction using LES. I generate the turbulence at the inlet implementing a recycling technique (similar to that of Lund et all) using directMapped BC. Now, my mesh has to be able to deform, however when I run my case I get:
Create time
Create dynamic mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: laplaceFaceDecomposition
--> FOAM FATAL ERROR:
Unknown faceTetPolyPatchFaceDecomp type directMappedPatch. Valid faceTetPolyPatchFaceDecomp types are :
7
wall
processor
wedge
patch
empty
ggi
symmetryPlane
From function faceTetPolyPatchFaceDecomp::New(const polyPatch&, const tetPolyBoundaryMeshFaceDecomp&)
in file tetPolyMeshFaceDecomp/tetPolyPatches/faceTetPolyPatch/newFaceTetPolyPatchFaceDecomp.C at line 59.
FOAM exiting
Does this mean that deformable meshes cannot be used with DirectMapped Bc's? Do I have to set three different domains and link them together? (one recycling domain, one fluid domain with deformable mesh and one solid domain)
I will appreciate any help or suggestions. Thanks
gascortado is offline   Reply With Quote
Old   January 3, 2013, 14:14
cutty4sark is on a distinguished road
Unfortunately, I cannot help but I can report a similar error message. I'm attempting to use the regionCouple boundary in OpenFOAM-1.5-dev which throws the same error that you reported. If anyone has an idea of what we're doing incorrectly, I would certainly appreciate a pointer in the correct direction. I've been pouring over the source files to try and gain a better understanding, but I'm still stuck.
Regards
cutty4sark is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
2way FSI Fluent Mechanical SETUP Problems MainzerKaiser ANSYS 7 May 20, 2016 11:22
FSI problems lingdeer CFX 5 December 5, 2011 13:30
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 04:08
