April 11, 2011, 12:39 |
OpenFOAM: LES turbulence model names
Rep Power: 15 |
hi,
I want to use the WALE (Wall adapting local eddy viscosity) model and the kinetic energy subgrid-scale model for my final year undergraduate project. In openfoam they aren't called the same names as above. I have established that the dynOneEqEddy is the kinetic energy subgrid-scale model by looking at the transport equations in the programmers guide. I am not as sure on the WALE model, i think it is the locDynOneEqEddy but i can't confirm it. Could someone let me know if I am correct about the kinetic energy model and the WALE model, and if not, which are the corresponding openfoam models? cheers Ollie |
April 12, 2011, 07:25 |
Francois
Rep Power: 20 |
Dear Ollie,
To my knowledge there is nothing like the WALE model implemented in OpenFOAM. As a mater of fact, none of the LES models in OpenFOAM are dynamically local. They have dynamic coefficients changing in time, but with global coefficients computed over the whole domain. Basically, if you want a WALE model, you will have to implement it yourself based on an existing model. Kind regards, Francois. |
April 12, 2011, 13:26 |
Rep Power: 15 |
cheers Francois,
another thing, was I right about dynOneEqEddy is the kinetic energy subgrid-scale model (The model proposed by Kim and Menon (1999))?. I ask because the transport equations for the dynOneEqEddy and the LocdynOneEqEddy are very similar. My project supervisor dosn't want me to use the Smagorinsky model and its dynamic version as they have been studied widely for the type of flow I am looking at (High Reynolds number flow over a cylinder). That is why I wanted to use the Dynamic Kinetic Energy SGS and the WALE model. As openfoam dosent have the WALE model, would the LocdynOneEqEddy be a good choice? cheers Ollie |
April 13, 2011, 10:11 |
Francois
Rep Power: 20 |
I stand corrected. locDynOneEqEddy returns a volScalarField for ck and ce, which would imply a local computation of the coefficients at every time step..
That's the main difference between dynOneEqEddy and locDynOneEqEddy, with the former having a single coefficient computed over the whole domain. And as for the choice of your models and whether they would be usable for what you want to do, you'll have to look at the OpenFOAM code and understand what is happening, and compare it to the theoretical models you have in mind. You'll probably have to do some coding of your own if you are planning on using some exotic SGS models. Kind regards, Francois. |
April 27, 2012, 05:10 |
WALE LES model in OpenFOAM?
Vinay Ramohalli Gopala
Rep Power: 17 |
I am wondering if anyone tried the implementation of the WALE model for LES in OpenFOAM?
January 7, 2013, 10:24 |
Albrecht vBoetticher
Rep Power: 16 |
At LTTRostock they have recently implemented a dynamic mixed version of Meneveaus lagrangian SGS model, I think this is already a step forward for flows in complex geometry. But the dynamic mixed WALE according to http://link.springer.com/chapter/10....LI=true#page-1 seems to be even superior...
multiphaseInterFoam for RAS turbulence model | chiven | OpenFOAM Bugs | 8 | December 6, 2017 02:08 |
adapt offset cylinder model for les turbulence | shackman287 | OpenFOAM | 0 | August 19, 2010 21:10 |
Rotta's k-kL Turbulence model in OpenFOAM?? | barath.ezhilan | OpenFOAM | 1 | August 14, 2009 05:55 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
Sinclair Model + secondary turbulence | Yi | FLUENT | 0 | October 26, 2001 13:37 |
