Where is the attach/Detach face?
Like Tree1Likes
  • 1 Post By mturcios777
Old   March 9, 2013, 18:44
Default Where is the attach/Detach face?
Sasan Ghomi
sasanghomi is on a distinguished road
Dear foamers ,
I want to simulate an engine with sonicTurbDyMEngineFoam and simpleEngineTopoFVmesh library....
Can anyone explain where is the attach or detach boundary?
I attached two pictures (from articles-authors : prof.jasak&Prof.luchini)
there is a chamfer at the end of the manifold (both 2D and 3D case)..what is it? in the 2D case is it a face or an edge? in the 3D case is it a volume or a face?
Does the fluid flow go through inside of it(when the valve closed)???? If yes, So where is attach or detach face??
If the fluid flow go through inside of the chamfer I think there is no any face (in your boundary faces) that it can close the manifold completely....
please anyone show me where is the attach or detach face????
I approciate any help...
Thanks and best regards,
Sasan.
sasanghomi is offline   Reply With Quote
Old   March 12, 2013, 09:11
Sasan Ghomi
I appreciate any help...
where is the valve detach/attach face?
Is it a horizontal patch above the valve (that specified by using faceSet)? Or it is a patch that constructed from faces of valve?
thanks,
Sasan.
Old   March 12, 2013, 11:48
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
The attachDetach faces are the regions that will alternate between being open and being a wall to simulate the opening/closing of the valve, as otherwise you have to remesh to close/open the valves. I've usually seen it as a set of faces defined between the poppet top and valve seat, perpendicular to both.
sasanghomi likes this.
mturcios777 is offline   Reply With Quote
