Progamming issue: how do i get acces to the actual values of k-epsilon?
Old   July 7, 2010, 12:18
Exclamation Progamming issue: how do i get acces to the actual values of k-epsilon?
Sabin Ceuca
sabin.ceuca is on a distinguished road
after some struggling with the setup of OpenFOAM simulations, I have now started to write my own models. My first difficulties arose when i wanted to get access to the desired variables. What I actualy mean is lets take for example the density or the specific heat capacity which can be called using "twoPhaseProperties.variableName". Now I would like to have access to the actual values of for instance k-epsilon variables, but I would like to understand how do I generally find out where certain variables are computed and how to access them?
Greetings
Sabin
sabin.ceuca is offline   Reply With Quote
Old   July 8, 2010, 03:18
Kathrin Kissling
kathrin_kissling is on a distinguished road
Hello Sabin,
could you tell me which solver and which version you're using?
In your solver (interFoam.C) which might be for example rasInterFoam (older version) or now interFoam (actual version) you will find a line
turbulence->correct();
which will actually call the turbulence model.
the object turbulence is assigned in the createFields.H file in
00095 // Construct incompressible turbulence model
00096 autoPtr<incompressible::turbulenceModel> turbulence
00097 (
00098 incompressible::turbulenceModel::New(U, phi, twoPhaseProperties)
00099 );
There you can see where it comes from. It is an incompressible turbulenceModel, so you have to search in src/turbulenceModel/incompressible/turbulenceModel
or
src/turbulenceModel/RAS/incompressible/RASModel, depending on the version you're using.
There you will find the files turbulenceModel.C turbulenceModel.H and newTurbulenceModel.C
respectively RASModel.C RASModel.H and newRASModel.C
Here you will find the reading from your turbulence dictionary and the setting of the turbulence model.
From now on it depends which model you are using. If you give me more information I can try to help you figuring it out.
Best
Kathrin
kathrin_kissling is offline   Reply With Quote
Old   July 8, 2010, 06:12
Sabin Ceuca
Morning Kathrin,
thanks for the answer
Sorry that I forgot to mention which solver I am using (it's interFoam from OF 1.6) . By looking into this http://foam.sourceforge.net/doc/Doxygen/html/incompressible_2turbulenceModel_2turbulenceModel_8 H_source.html I would understand that if I need the turbulence kinetic energy (k) I should be able to call it by volScalarField turbKinEnergy = turbulence.k(); , because the turbulence kinetic energy is defined in the file turbulenceModel.H as:
virtual tmp<volScalarField>k() const = 0; But it's not working.. During the compilation I get the error ‘class Foam::autoPtr<Foam::incompressible::turbulenceMode l>’ has no member named ‘k’
Do you have an idea how I can access this variable?
Greetings
Sabin
Old   July 8, 2010, 06:39
Robertas N.
r08n is on a distinguished road
Originally Posted by sabin.ceuca View Post
I would understand that if I need the turbulence kinetic energy (k) I should be able to call it by [COLOR=royalblue]volScalarField turbKinEnergy = turbulence.k();
volScalarField turbKinEnergy = turbulence().k();
('turbulence' with parentheses).
r08n is offline   Reply With Quote
Old   July 8, 2010, 07:00
Thumbs up
Sabin Ceuca
Thanks r08n and Kathrin for helping me out, within such a short time.
Old   August 29, 2012, 14:41
Default Could you please explain wht this works?
xinyu
xinyu is on a distinguished road
I recently encountered the same problem and solved using this thread. Could you kindly explain why we need to add parentheses here? Is this something to do with the tmp type defined in the turbulence library?
Thanks a lot,
Xinyu
xinyu is offline   Reply With Quote
Old   March 14, 2013, 03:29
sfigato's Avatar
Marco Longhitano
sfigato is on a distinguished road
Send a message via Skype™ to sfigato
Dear Foamers,
I recently encountered the same problem regarding the access to the turbulence kinetic energy! By follwing the advice of this thread
I added:
// * * * * * * * * * * * * * * * * Constructors * * * * * * * * * * * * * * //
Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::S chnerrSauer
const volVectorField& U,
const surfaceScalarField& phi,
const volScalarField& turbKinEnergy = turbulence().k(),
const word& alpha1Name
and I got this compiling error:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:54:54: error: ‘turbulence’ was not declared in this scope
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:50:1: error: prototype for ‘Foam:haseChangeTwoPhaseMixtures::SchnerrSauer:: SchnerrSauer(const volVectorField&, const surfaceScalarField&, const volScalarField&, const Foam::word&)’ does not match any in class ‘Foam:haseChangeTwoPhaseMixtures::SchnerrSauer’
In file included from phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.C:26:0:
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.H:61:7: error: candidates are: Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::S chnerrSauer(const Foam:haseChangeTwoPhaseMixtures::SchnerrSauer&)
phaseChangeTwoPhaseMixtures/SchnerrSauer/SchnerrSauer.H:101:9: error: Foam:haseChangeTwoPhaseMixtures::SchnerrSauer::S chnerrSauer(const volVectorField&, const surfaceScalarField&, const Foam::word&)
make: *** [Make/linux64GccDPOpt/SchnerrSauer.o] Fehler 1
Can anyone help me!?
Regards
Marco
sfigato is offline   Reply With Quote
Old   March 20, 2013, 20:50
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Marco,
This is because you can't define a initialize a parameter in the constructor in the manner you are attempting.
wont work. instead try just
const volScalarField& turbKinEnergy,
and when you initialize your constructor...make sure to pass the right argument i.e. the TKE.
chegdan is offline   Reply With Quote
Old   March 21, 2013, 01:18
sfigato's Avatar
Marco Longhitano
Hi Daniel,
First I thanks you for your reply!
I am dealing with another problem! I implement a homogenoeus multiphase problem using pimple loop! I add a new transport scalar equation with variable density and I want to update my density after tha computing of the scalar quantity!
Here is the code :
// Solve Mass Fraction Equation for the Vapour
//Mass Fraction of Vapour and Air
Info<< "Calculating field fv\n" << endl;
volScalarField fv
IOobject
"fv",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
rho2*alpha2/rho
Info<< "Calculating field fg\n" << endl;
volScalarField fg
IOobject
"fg",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
rho3*alpha3/rho
//Turbulence Saturation Pressure
Info<< "Calculating field pV\n" << endl;
volScalarField pV
IOobject
"pV",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::NO_WRITE
(scalar(0.39)*rho1*turbulence->k()) + pSat
//Scalar Transport Equation for Mass Fraction
fvScalarMatrix fvEqn
fvm::ddt(rho, fv)
+ fvm::div(rhoPhi /*phi*/, fv)
- fvm::laplacian(Gammaf,fv)
- fvm::Sp(Ce*rho1*rho2*sqrt(2*(p-pV)/3/rho1)*sqrt(turbulence->k()/sigma),fv)
- fvm::Sp(Cc*rho1*rho1*sqrt(2*(p-pV)/3/rho1)*sqrt(turbulence->k()/sigma),fv)
fvEqn.relax();
solve( fvEqn == Ce*rho1*rho2*sqrt(2*(p-pV)/3/rho1)*sqrt(turbulence->k()/sigma)*(1-fg));
//Update of All Phases Coeffcients
rho == scalar(1)/((fv/rho2)+(fg/rho1)+((scalar(1)-fv-fg)/rho1));
alpha2 == fv*(rho/rho3);
alpha3 == fg*(rho/rho2);
alpha1 == (1- alpha2 -alpha3);
//rhoPhi == rho*phi;
In order to updatw my volum fraction coeffcients and the density, are the bold lines enough?
Moreover, what about the rhoPhi variable?
Here is the whole solver!
Thanks
Regards
Marco
programming
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 08:30
k and epsilon Values for High Pressure Water nikhiljain.iitk FLUENT 0 March 12, 2010 06:06
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 20:21
Modify, G_k,k and epsilon values on wall functions Javier Larrondo FLUENT 0 September 15, 2008 21:34
Values of k & epsilon in the moving wall ghlee Main CFD Forum 1 August 16, 1999 12:42
