reactingfoam - pressure field
Old   March 17, 2013, 08:14
Default reactingfoam - pressure field
Jacopo
yaqb is on a distinguished road
I have just started with OpenFoam, so I am still lost in the dark.
I have a question.Can anyone explain me why the reactingFoam does not calculate the pressure field? I have run the tutorial example and the pressure field is uniform from the beginning until the end of the simulation. What is the reason of that?
The screenshot I have uploaded is from the 0.3 sec.
yaqb is offline   Reply With Quote
Old   March 18, 2013, 11:26
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Please describe your case setup and boundary conditions. Right now you don't have much for us to go on...
mturcios777 is offline   Reply With Quote
Old   March 18, 2013, 13:59
Jacopo
Thank you for you answer
- In fact I have been trying to modify the reactingFoam to make it working with changed geometry and always got the uniform pressure field.
-Than I run the case from tutorial - just went to the tutorial and run the case without changing anything . At the end I also got the uniform pressure - it is shown on the picture I have uploaded.
It just have no sense for me.... why the solver does not compute pressure in this case?
Old   March 19, 2013, 10:55
Marco A. Turcios
Which tutorial are you running? I ask because that looks like the geometry for cavity, and the geometry for reactingFoam (based on PitzDaily) is very different.
Old   March 20, 2013, 01:43
Karl-Johan Nogenmyr
kalle is on a distinguished road
I guess you are running the counterFlowFlame tutorial. Default, the tutorial saves out in ascii with 6 digits precision. This case operates at a pressure of 1e5 Pa, while flow induced pressure differences are about 0.015 Pa. These small differences are completely lost at save-out. Switching to binary in controlDict, and you can see the differeneces. It appears though as if paraview is having trouble displaying the field still.
Hack: switch to ascii and precision 16. Open 0.3/p in a text editor and search replace "100000." with "0." to remove the offset of 100000. Now paraview will show a nice smooth pressure field actually used by the solver.
K
kalle is offline   Reply With Quote
Old   March 21, 2013, 04:54
Default Solved
Jacopo
Yes! You were completely right , the pressure varies less than 1 Pa - right now I can see everything
Thanks a lot!
Pressure far field vs Velocity inlet/Pressure Outlet cocobi FLUENT 1 January 29, 2013 10:45
custom pressure field at the faces Souviktor FLUENT 0 April 3, 2009 08:09
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
order of magnitude analysis atit koonsrisuk Main CFD Forum 3 July 27, 2000 11:59
