July 11, 2013, 11:42 |
CFD Results Without Data
n/a
Rep Power: 16 |
Hello Foamers!!!! I would like any feedback that can be rendered on this particular matter. So, I am in the process of writing my PhD thesis and do have 3 LES test cases that I've worked on. The first 2 were nicely validated with experimental data; I have not been able to find any valuable experimental measurements for the third case. I did find some data, except water was employed as the working fluid, as opposed to my computations that utilized air. What do you guys think? The third case is really interesting (vortex instability flow over horizontal heated flat plate) and really want to present it for my PhD defense. Do you guys think I can employ the same parameters as those of the water experiment in my LES air computations just to show that my results are "somewhat" reliable? Or is there no need to since my first two cases has validated my methodology?
July 11, 2013, 23:47 |
n/a
Rep Power: 16 |
Problem solved!!!!!
CFD Design...The CFD Future | John C. Chien | Main CFD Forum | 20 | November 19, 2015 23:40 |
CFD vs Experimetal Results for Aerofoil | owhelan | Main CFD Forum | 3 | March 25, 2010 10:54 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 21:10 |
PC vs. Workstation | Tim Franke | Main CFD Forum | 5 | September 29, 1999 15:01 |
Since Last June | John C. Chien | Main CFD Forum | 3 | July 12, 1999 09:38 |
