June 13, 2013, 08:35 |
Cl(f) and Cl(r) what it means?
kunar
hai friends,
I am doing 2d airfoil analysis, i have doubt about the result i got ie Cl(f) and Cl(r) it means what? and also i mention in red colour Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : simpleFoam Date : Jun 11 2013 Time : 14:42:35 Host : "ubuntu" Case : /home/toshiba/OpenFOAM/toshiba-2.1.0/run/tutorials/incompressible/simpleFoam/ku/airFoil2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting RAS turbulence model SpalartAllmaras SpalartAllmarasCoeffs { sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cv2 5; } No field sources present SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 0.999993, Final residual = 0.0558381, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 1, Final residual = 0.0760732, No Iterations 2 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0991895, No Iterations 39 time step continuity errors : sum local = 0.00119979, global = 6.26709e-16, cumulative = 6.26709e-16 smoothSolver: Solving for nuTilda, Initial residual = 0.999999, Final residual = 0.0701398, No Iterations 4 ExecutionTime = 36.7 s ClockTime = 37 s forces output: forces(pressure,viscous)((257697 5.20299e+06 7.66604e-16),(6.53254 1.33905 -1.89121e-21)) moment(pressure,viscous)((-3.39084e-17 -1.06156e-16 2.50963e+06),(4.47879e-23 -2.14236e-22 0.66735)) forceCoeffs output: Cm = 901.996 Cd = 415.85 Cl = 1857.68 Cl(f) = 1830.84 Cl(r) = 26.8427 Time = 2 smoothSolver: Solving for Ux, Initial residual = 0.623192, Final residual = 0.0517858, No Iterations 4 smoothSolver: Solving for Uy, Initial residual = 0.445407, Final residual = 0.0284221, No Iterations 4 GAMG: Solving for p, Initial residual = 0.711508, Final residual = 0.0608906, No Iterations 11 time step continuity errors : sum local = 0.000802196, global = 1.48748e-15, cumulative = 2.11418e-15 smoothSolver: Solving for nuTilda, Initial residual = 0.258696, Final residual = 0.0187245, No Iterations 4 ExecutionTime = 45.88 s ClockTime = 46 s forces output: forces(pressure,viscous)((168327 3.88357e+06 2.72499e-16),(23.6262 2.65695 -2.24632e-21)) moment(pressure,viscous)((-2.10668e-17 -5.5126e-17 1.89813e+06),(5.34685e-23 -6.75307e-22 1.37948)) forceCoeffs output: Cm = 682.213 Cd = 301.9 Cl = 1385.1 Cl(f) = 1374.76 Cl(r) = 10.3358 Last edited by wyldckat; June 15, 2013 at 15:17. Reason: Added the [CODE] delimiters |
June 15, 2013, 15:34 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Hi Kumar,
Most of these you can find out about them by using Google. For example, use the following text in Google: Code:
openfoam "fileModificationChecking"
Bruno
June 16, 2013, 05:32 |
kunar
Thanks Bruno for your kind response.
For laminar case 1. I remove nut & nu from O folder and i change p & U and in system folder for i make changes in controldict according to my velocity 2.I didnt change in transport Properties in constant folder 3. RASProperties // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // RASModel SpalartAllmaras; [instead of SpalartAllmaras i change laminar] turbulence on; [turbulence off] printCoeffs on; // ************************************************** *********************** I think this is correct,if any thing i have to make changes,please let me know. my Reynolds number is 1000 once again thanks Bruno, you are coming forward to help me a lot Thanks for your valuable time |
June 16, 2013, 08:55 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
It seems to be OK for running in laminar flow. All other configurations that were meant for turbulence in "system/fvSolution" and "system/fvSchemes", won't be used either way, so there is no need to remove them from those two files. Best regards, Bruno
June 17, 2013, 03:08 |
kunar
Hai Bruno thanks a lot for your help, everything works fine.
I forgot to ask for turbulent case,while doing angle of attack 10. I set x velocity and y velocity in internal field in O folder for U // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (2.2946 0.4046 0); boundaryField { inlet { type freestream; freestreamValue uniform (2.2946 0.4046 0); } outlet { type freestream; freestreamValue uniform (2.2946 0.4046 0); but I took default value for nuTilda and nut ie .14 whatever in that folder. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -1 0 0 0 0]; internalField uniform 0.14; boundaryField { inlet { type freestream; freestreamValue uniform 0.14; } outlet { type freestream; freestreamValue uniform 0.14; } I think it seems unimportant nut & nuTilda.Actually what i understand is the internal field value is to set the same as the inlet value( velocity= 2.33 m/s)but Anyhow it will be overwritten after the first time step. This is correct or wrong,please let me know. |
June 17, 2013, 17:04 |
Bruno Santos
Rep Power: 128 |
Hi Kumar,
Yes, if I remember correctly, "nut" and "nuTilda" are mostly calculated by the turbulence models. The set-up of the boundary conditions for those fields is almost just a formality, in the sense that they will be calculated if they are allowed to do so. If I'm not mistaken, if you were to set one of the conditions in "nut" or "nuTilda" to zero gradient, such as this: Code:
inlet { type zeroGradient; } Another example is the "symmetry" type of condition, which the solver should allow, e.g.: Code:
symmetricWall { type symmetry; } Bruno PS: Have a look into the post the second link in my signature links to, because in it I explained how you can paste code
June 18, 2013, 02:46 |
kunar
Thanks Bruno, Have a nice Day
June 18, 2013, 05:55 |
kunar
Hai, Bruno
I am trying to do 3D wing Analysis for Unsteady case.I took NACA0012 airfoil and extrude 5cm length from Back Face of Domain.let Reynolds number 1000 and velocity is 3m/s. DOMAIN Boundary Condition Side 1- velocity inlet Side 2-pressure outlet Top,Bottom,Front Face-symmetry Back Face & wing - Wall I did meshing part in gambit. I want to flap the wing up & down for [-5 to +5 Amplitude angle]. For this I want to see the lift and Drag. Somebody did in Fluent (Dynamic Mesh), the same thing I want to do in open foam, please see the link its you tube video (ie Flapping 3d wing -Pressure contours). LINK: [ http://www.youtube.com/watch?v=RjwV8TzW6a8 ] For domain, Please see the attached my image for your reference.If you have any idea, please give me your suggestions. Thanks for your valuable Time Last edited by hhh; June 18, 2013 at 10:48. |
[Other] Failed 1 mesh check | camoesas | OpenFOAM Meshing & Mesh Conversion | 26 | April 4, 2018 18:53 |
kEpsilon divergence | s.m | OpenFOAM Running, Solving & CFD | 0 | May 27, 2013 09:30 |
