parallel processing Error
Old   October 12, 2013, 17:31
Default parallel processing Error
Arjang Behnoud
AmirBaqa1987 is on a distinguished road
Hi Dear All
I can not run my case in parallel while I've run the case in serial with no problem.
the geometry is pipe with length and diameter equal to 4m and 0.025m in order.
the Error :
[1] #0  Foam::error::printStack(Foam::Ostream&)[3] #0  Foam::error::printStack(Foam::Ostream&)[2] #0  [4] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&)[0] #0  [5] #0  Foam::error::printStack(Foam::Ostream&)Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[4] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/p in "/opt/openfoam211/platforms/llatforms/linux64GccDPOptinux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1/lib/libOpenFOAM.so"
[3] #1    Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int) in  in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so""/opt/openfoam211/platforms/l
[0] #1  inux64GccDPOpt/lib/libOpenFOAM.so"
Foam::sigFpe::sigHandler(int)[5] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #2   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[5] #2   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[4] #2   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #2   in "/lib/x86_64-linux-gnu/libc.so.6" in "/opt/openf
[3] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) constoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2   in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[4] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3  Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[5] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
 in "[1] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&)/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[4] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #4  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[1] #5   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[3] #5   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[5] #5   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[2] #5   in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[4] #5  Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve()Foam::fvMatrix<double>::solve() in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[0] #5  Foam::fvMatrix<double>::solve() in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[1] #6   in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[4] #6  Foam::fvMatrix<double>::solve() in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[3] #6   in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[5] #6   in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[2] #6
[0] #6
[5]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[5] #7  __libc_start_main[1]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[1] #7  __libc_start_main
[3]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/li[4]  in "/home/amir/Opnux64GccDPOpt/bin/nanoHeatSimpleFoam"
[3] #7  __libc_start_mainenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[4] #7  __libc_start_main[2]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[2] #7  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[5] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[4] #8  [0]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[0] #7  __libc_start_main
[1] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[3] #8   in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #8
[amir-VPCF22CFX:14344] *** Process received signal ***
[amir-VPCF22CFX:14344] Signal: Floating point exception (8)
[amir-VPCF22CFX:14344] Signal code:  (-6)
[amir-VPCF22CFX:14344] Failing at address: 0x3e800003808
[amir-VPCF22CFX:14344] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fd753b934a0]
[amir-VPCF22CFX:14344] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fd753b93425]
[amir-VPCF22CFX:14344] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fd753b934a0]
[amir-VPCF22CFX:14344] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h+0xd95) [0x7fd754bc5e55]
[amir-VPCF22CFX:14344] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7fd755c59307]
[amir-VPCF22CFX:14344] [ 5] nanoHeatSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xdb) [0x428d1b]
[amir-VPCF22CFX:14344] [ 6] nanoHeatSimpleFoam() [0x419f7b]
[amir-VPCF22CFX:14344] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fd753b7e76d]
[amir-VPCF22CFX:14344] [ 8] nanoHeatSimpleFoam() [0x41c73d]
[amir-VPCF22CFX:14344] *** End of error message ***
[3]  in "/home/amir/OpenFOAM/amir-2.1.1/platforms/linux64GccDPOpt/bin/nanoHeatSimpleFoam"
[amir-VPCF22CFX:14342] *** Process received signal ***
[amir-VPCF22CFX:14342] Signal: Floating point exception (8)
[amir-VPCF22CFX:14342] Signal code:  (-6)
[amir-VPCF22CFX:14342] Failing at address: 0x3e800003806
[amir-VPCF22CFX:14342] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fab381b44a0]
[amir-VPCF22CFX:14342] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7fab381b4425]
[amir-VPCF22CFX:14342] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7fab381b44a0]
[amir-VPCF22CFX:14342] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h+0xd95) [0x7fab391e6e55]
[amir-VPCF22CFX:14342] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7fab3a27a307]
[amir-VPCF22CFX:14342] [ 5] nanoHeatSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xdb) [0x428d1b]
[amir-VPCF22CFX:14342] [ 6] nanoHeatSimpleFoam() [0x419f7b]
[amir-VPCF22CFX:14342] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7fab3819f76d]
[amir-VPCF22CFX:14342] [ 8] nanoHeatSimpleFoam() [0x41c73d]
[amir-VPCF22CFX:14342] *** End of error message ***
[amir-VPCF22CFX:14341] *** Process received signal ***
[amir-VPCF22CFX:14341] Signal: Floating point exception (8)
[amir-VPCF22CFX:14341] Signal code:  (-6)
[amir-VPCF22CFX:14341] Failing at address: 0x3e800003805
[amir-VPCF22CFX:14341] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f4e0d4914a0]
[amir-VPCF22CFX:14341] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f4e0d491425]
[amir-VPCF22CFX:14341] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x7f4e0d4914a0]
[amir-VPCF22CFX:14341] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam5PBiCG5solveERNS_5FieldIdEERKS2_h+0xd95) [0x7f4e0e4c3e55]
[amir-VPCF22CFX:14341] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7f4e0f557307]
[amir-VPCF22CFX:14341] [ 5] nanoHeatSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xdb) [0x428d1b]
[amir-VPCF22CFX:14341] [ 6] nanoHeatSimpleFoam() [0x419f7b]
[amir-VPCF22CFX:14341] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f4e0d47c76d]
[amir-VPCF22CFX:14341] [ 8] nanoHeatSimpleFoam() [0x41c73d]
[amir-VPCF22CFX:14341] *** End of error message ***
mpirun noticed that process rank 3 with PID 14342 on node amir-VPCF22CFX exited on signal 8 (Floating point exception).
2 total processes killed (some possibly by mpirun during cleanup)
maybe the problem is that some where division by zero is happen because of poor mesh quality.I've generated the mesh in following manner:
(110 10 10)
your help is appreciated.
Thanks
Arjang
AmirBaqa1987 is offline   Reply With Quote
Old   October 12, 2013, 20:01
fumiya's Avatar
Fumiya Nozaki
fumiya is on a distinguished road
Are you able to successfully run your solver in parallel if you change the decomposition method?
Fumiya
fumiya is offline   Reply With Quote
Old   October 13, 2013, 03:18
Arjang Behnoud
Originally Posted by fumiya View Post
Fumiya
Hi Dear Fumiya
no, I've changed the decomposition method , once I've selected simple method and another time hierarchical method but I was not successful .
Old   October 15, 2013, 13:18
Arjang Behnoud
nobody can help !!!
Old   October 15, 2013, 16:09
Retired Super Moderator
Bruno Santos
Greetings to all!
@Arjang: Well... it's possible to help you, but not with just this little amount of information . To understand what I mean, read this: http://www.cfd-online.com/Forums/ope...-get-help.html
Because from the output you provided, the only thing that can be seen is that:
  1. There was a SIGFPE: http://en.wikipedia.org/wiki/SIGFPE#SIGFPE
  2. It occurred in:
    Foam::PBiCG::solve
And that's it. There is nothing else that can be deduced from this output!
So, given the amount of available information, the only suggestion I can make is this - read this page: http://openfoamwiki.net/index.php/HowTo_debugging
Best regards,
Bruno
Old   November 5, 2013, 01:48
Arjang Behnoud
Thanks Dear Bruno
I've solved the problem by using your tip.
the problem was with mesh quality.
best regards.
Arjang
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 07:11
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
