January 6, 2014, 17:24 |
what wclean means
Rep Power: 14 |
Hi
I wonder what wclean means and when we normally use this command Thanks |
January 7, 2014, 01:37 |
Bernhard
Rep Power: 21 |
wclean is a script, you can check its contents in OpenFOAM-2.1.0/wmake. Normally you would use this command to clean up the directory of a solver or library: it just removes all the files that are not necessary for compilation, and thus only keeps the essential source files. Also, it can be wise to run wclean during development, such that you are sure that you are not working with outdated dependencies.
Cl(f) and Cl(r) what it means? | hhh | OpenFOAM | 7 | June 18, 2013 05:55 |
What means "bounding epsilon"? | gara1988 | OpenFOAM Running, Solving & CFD | 3 | October 29, 2012 08:59 |
What does wrongOrientedFaces means? | ivan_cozza | OpenFOAM Running, Solving & CFD | 0 | January 20, 2011 05:25 |
BC evaluation by means of external lists allocated in the solver | shrina | OpenFOAM Running, Solving & CFD | 2 | January 18, 2007 11:29 |
plot order points... what does it means ? | Cyril | FLUENT | 0 | June 7, 2006 05:56 |
