High resolution image with parafoam
Old   January 21, 2014, 05:23
Default High resolution image with parafoam
Andrea Ferrari
Andrea_85 is on a distinguished road
Hi all,
i am trying to save high resolution images of my simulation with parafoam but it looks much more complicated than what it should be or maybe i am just missing something.
When i use "save screenshoot" with the default resolution suggested by parafoam everything works fine. Problem rises if i try, for istance, to double the resolution (double pixels each directions). The created image is not really the original one with double resolution but it seems that parafoam just extends the borders, adding more "background" to the image, and making the part of interests smaller.
So what i am missing here? Is it possibile to save high resolution image with parafoam? and if yes, how?
Thanks
andrea
Andrea_85 is offline   Reply With Quote
Old   January 21, 2014, 08:11
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
What version of paraview do you use? Just tested saving large screenshots with 4.0.1 and it does it right.
alexeym is offline   Reply With Quote
Old   January 21, 2014, 08:42
Andrea Ferrari
i am using paraview 3.12.0 which is included in the last avaible version of openFoam.
best
andrea
Old   January 23, 2014, 05:14
akidess's Avatar
Anton Kidess
I don't think that was possible in Paraview 3.12. I strongly recommend upgrading to Paraview 4.x, a lot of things have improved. Just download a binary from paraview.org and use the built-in openfoam loader; you will have it running in two minutes.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   January 23, 2014, 05:35
Andrea Ferrari
Thanks
ill try to update it. Are you saying that it is not necessary to re-compile ThirdParty?
best
andrea
Old   January 23, 2014, 06:39
akidess's Avatar
Anton Kidess
Unless you absolutely insist on running paraFoam / the OpenCFD plugin instead of what is already built into paraview natively, no, you do not have to recompile ThirdParty.
high mesh resolution causing vortex pimpleFoam mvoss OpenFOAM Running, Solving & CFD 2 March 8, 2012 07:06
Do high grid resolution capture accurate shocks? Explicit someone Main CFD Forum 1 November 10, 2008 05:48
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
high resolution MHD code merryfish Main CFD Forum 0 February 3, 2007 22:02
High Resolution Scheme Vinod Dhiman Main CFD Forum 0 August 2, 2005 05:55
