Hi! I have extra wall surfaces in the interior I want can't remove
Old   August 22, 2014, 19:52
Question Hi! I have extra wall surfaces in the interior I want can't remove
Japan Patel
japan25 is on a distinguished road
Hi!
I am trying to generate a box shell (outer box with dimensions 6 by 6 by 10) and inner dimensions (5.5 by 5.5 by 10).
I have attached my blockMeshDict file, Geometry generated (of1.jpg), mesh generated (of2.jpg), and erroneous wall patch (of3.jpg).
What this does is it prescribes wall boundaries in the interior of the problem which isn't correct. I need to fix it.
Initially I tried to specifically specify faces with walls - no slip. But that gave me error of no neighbouring cells. I tried changing the ordering of my vertices with face definitions but it kept on giving me the same error. I have that commented out in the blockMeshDict file.
If someone could please help, I'd be really grateful.
Thanks,
Japan
blockMeshDict.txt
japan25 is offline   Reply With Quote
Old   August 23, 2014, 02:44
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Good morning,
You need more than 4 blocks to mesh that geometry in blockMesh. Interfaces between blocks should be matching, which they do not in the attached mesh.
Please see more on blockMesh in the UserGuide.
Kind regards,
Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   September 7, 2014, 19:08
Japan Patel
Sir,
I tried it again, this time with matching internal faces but I still couldn't get rid of that effect. What should I do?
Is there a boundary condition like interior boundary - that way I could just specify those faces as interior.
Thanks!
Wall treatment with OpenFOAM roby OpenFOAM Running, Solving & CFD 48 May 28, 2021 11:38
help with wall functions Nick Georgiadis Main CFD Forum 10 January 17, 2017 10:03
Wall function in adverse pressure gradients stephane baralon Main CFD Forum 11 September 2, 1999 04:05
Wall functions Abhijit Tilak Main CFD Forum 6 February 5, 1999 01:16
Law of the wall on curved surfaces Rasputin Main CFD Forum 3 November 2, 1998 09:28
