Any pipe (channel) flow tutorial by 'twoPhaseEulerFoam' in version 2.3.0? |
April 14, 2014, 08:32 |
X Meng
Rep Power: 13 |
Hi guys.
For solver 'twoPhaseEulerFoam' 2.3.0, a vertical fluidised bed case can be found in tutorial. However, if develop the case to a horizontal pipe with inlet and outlet BCs, I got apparently wrong results again and again, in both velocity and pressure. My question is, for the solver 'twoPhaseEulerFoam' 2.3.0, does anyone have a normal pipe flow case with good result? Really appreciate. |
April 27, 2014, 17:15 |
Getnet
Rep Power: 14 |
Hi Xiangyin,
I am also interested to use 'twoPhaseEulerFoam" for a channel/pipe flow. I am still on the planning phase and didn't do any simulations except the tutorials which come with the solver. Let me know if you have got any progresses. Thanks, Getnet |
May 5, 2014, 00:48 |
Hanniel Freitas
Rep Power: 14 |
Hey guys,
Did you managed to get a twoPhaseEulerFoam example for a pipe flow? I've recently started to simulate a filling of a pipe containing air with polymer and solid particles using the multiphaseEulerFoam, a close brother of the twoPhaseEulerFoam. I used the typical boundary conditions for a internal flow simulation, but there's no phase movement whatsoever. |
June 19, 2015, 07:25 |
Hey,
I would like to know if you had any success with simulations of channel/pipe flow usinf twophaseeulerfoam. Best regards, Daneish |
June 24, 2015, 14:21 |
Dongyue Li
Rep Power: 17 |
Um, maybe the fast way to adopt the tutorial to a pipe will be changing g vector.
My OpenFOAM algorithm website: http://dyfluid.com By far the largest Chinese CFD-based forum: http://www.cfd-china.com/category/6/openfoam We provide lots of clusters to Chinese customers, and we are considering to do business overseas: http://dyfluid.com/DMCmodel.html |
Complex problem: Open Channel Flow | lett | FLUENT | 18 | November 10, 2018 18:30 |
Question on the boundary condition for open channel flow, please help! | ripperjack | OpenFOAM Running, Solving & CFD | 0 | September 13, 2013 11:44 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
Open channel flow tutorial | ezzhisham | FLUENT | 0 | September 18, 2011 11:51 |
Channel flow with twoPhaseEulerFoam | joao | OpenFOAM Running, Solving & CFD | 0 | September 27, 2007 09:05 |
