Boundary conditions for hydraulically developed flow in buoyantSimpleFoam
Old   July 1, 2015, 10:05
Default Boundary conditions for hydraulically developed flow in buoyantSimpleFoam
buffi is on a distinguished road
I want to set up a case where the flow is hydraulically developed, but the fluid enters the domain with a constant temperature. This means that I need
  • cyclic patches at the inlet and at the outlet,
  • a fan boundary condition for the pressure,
  • a cyclic boundary condition for the velocity and
  • fixedValue/zeroGradient (or equivalent) boundary conditions for the temperature.
The walls will have no-slip/constant temperature BCs. Here are my files from the 0/ directory:
p:
|  \\    /   O peration     | Version:  2.2.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0";
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 1e5;
boundaryField
  "walls"
    type         zeroGradient;
  "front|back"
        type empty;
  inlet
      type        fan;
      patchType     cyclic;
      f List<scalar> 1(-22.058);
      value         uniform 0;
  outlet
      type         fan;
      patchType     cyclic;
      value         uniform 0;
p_rgh:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p_rgh;
boundaryField
  "walls"
    type         zeroGradient;
  "front|back"
        type empty;
  inlet
      type        fan;
      patchType     cyclic;
      value         uniform 0;
  outlet
      type         fan;
      patchType     cyclic;
      value         uniform 0;
U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0.1 0 0);
boundaryField
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    front
        type            empty;
    back
        type            empty;
    inlet
        type            cyclic;
    outlet
        type            cyclic;
T:
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 293;
boundaryField
  "walls"
    type         fixedValue;
    value uniform 300;
  "front|back"
        type empty;
  inlet
    type fixedValue;
        value uniform 293;
  outlet
        type zeroGradient;
constant/thermophysicalProperties:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        nMoles          1;
        molWeight       18.02;
    thermodynamics
        Cp              4185;
        Hf              0;
    transport
        mu              1e-03;
        Pr              7;
buoyantSimpleFoam complains about
--> FOAM FATAL IO ERROR:
inconsistent patch and patchField types for
    patch type cyclic and patchField type fixedValue
which does not really surprise me, but do I circumvent it? I'm also not sure about p and p_rgh, which BCs should I use for those? They both have fan BCs above, but I don't think that's correct.
The flow is a 2D channel flow in horizontal direction, with heated walls (see T). I know that I should probably use a constant heat flux BC for T on the walls, but that's not the problem now.
Can anyone shed some light on this?
Regards
Christoph
buffi is offline   Reply With Quote
Old   September 5, 2015, 10:09
ajonuz is on a distinguished road
Hi Christoph,
did you manage to find a solution to your problem? I'm experiencing quite similar issue at the moment.
Best regards
Admir
ajonuz is offline   Reply With Quote
Old   August 22, 2019, 10:38
mm66 is on a distinguished road
I know it might be quite late to reply to this thread but for future reference, the boundary condition for T should include:
    Inlet
        type            fixedValue;
	patchType	cyclic;
        value     	uniform 298.15;
mm66 is offline   Reply With Quote
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 06:40
Boundary conditions in channel flow with wall model GCMS_A OpenFOAM Pre-Processing 0 April 21, 2015 08:47
Boundary conditions for boundary layer flow harry123 Main CFD Forum 2 February 14, 2015 05:19
Radiation interface hinca CFX 15 January 26, 2014 17:11
Proper Pressure Boundary Conditions for Buoyant Flow mchurchf OpenFOAM 0 March 25, 2010 12:16
