Boundary conditions for hydraulically developed flow in buoyantSimpleFoam |
July 1, 2015, 10:05 |
I want to set up a case where the flow is hydraulically developed, but the fluid enters the domain with a constant temperature. This means that I need
p: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { "walls" { type zeroGradient; } "front|back" { type empty; } inlet { type fan; patchType cyclic; f List<scalar> 1(-22.058); value uniform 0; } outlet { type fan; patchType cyclic; f List<scalar> 1(-22.058); value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object p_rgh; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 1e5; boundaryField { "walls" { type zeroGradient; } "front|back" { type empty; } inlet { type fan; patchType cyclic; f List<scalar> 1(-22.058); value uniform 0; } outlet { type fan; patchType cyclic; f List<scalar> 1(-22.058); value uniform 0; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0.1 0 0); boundaryField { walls { type fixedValue; value uniform (0 0 0); } front { type empty; } back { type empty; } inlet { type cyclic; } outlet { type cyclic; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 293; boundaryField { "walls" { type fixedValue; value uniform 300; } "front|back" { type empty; } inlet { type fixedValue; value uniform 293; } outlet { type zeroGradient; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } mixture { specie { nMoles 1; molWeight 18.02; } thermodynamics { Cp 4185; Hf 0; } transport { mu 1e-03; Pr 7; } } // ************************************************************************* // Code:
--> FOAM FATAL IO ERROR: inconsistent patch and patchField types for patch type cyclic and patchField type fixedValue The flow is a 2D channel flow in horizontal direction, with heated walls (see T). I know that I should probably use a constant heat flux BC for T on the walls, but that's not the problem now. Can anyone shed some light on this? Regards Christoph |
September 5, 2015, 10:09 |
Rep Power: 10 |
Hi Christoph,
did you manage to find a solution to your problem? I'm experiencing quite similar issue at the moment. Best regards Admir |
August 22, 2019, 10:38 |
Rep Power: 7 |
I know it might be quite late to reply to this thread but for future reference, the boundary condition for T should include:
Inlet { type fixedValue; patchType cyclic; value uniform 298.15; } |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Boundary conditions in channel flow with wall model | GCMS_A | OpenFOAM Pre-Processing | 0 | April 21, 2015 08:47 |
Boundary conditions for boundary layer flow | harry123 | Main CFD Forum | 2 | February 14, 2015 05:19 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
Proper Pressure Boundary Conditions for Buoyant Flow | mchurchf | OpenFOAM | 0 | March 25, 2010 12:16 |
