May 6, 2016, 04:48 |
Meshing with OpenFOAM: errore in checkMesh
Rep Power: 10 |
Hello everybody.
I'm quite new in OpenFOAM since I have been using it for some months, and I registered a problem in using snappyHexMesh. I am trying to mesh a domain around an airfoil in order to simulate compressible flows, but when I check mesh with checkMesh utility there's this errore message: ***Number of edges not aligned with or perpendicular to non-empty directions: 56148 <<Writing 83645 points on non-aligned edges to set nonAlignedEdges At the following link you can find my case: Mesh Thank you in advance for everyone is going to reply and help me. |
May 7, 2016, 13:33 |
Hassan Kassem
Rep Power: 17 |
This error mainly means that empty BC is used but the mesh isn’t 2D. The problem is that you are trying to create 2D mesh using snappyHexMesh which is 3D mesh generator. If you checked the mesh over the aerofoil, you will find that, there are more than one cell in the empty direction. The solution is easy, you can use extrudeMesh utility. Fortunately, there is a tutorial for this particular case. Please check wingMotion tutorial under pimpleDyMFoam tutorials directory. Best wishes, Hassan Kassem |
May 8, 2016, 08:46 |
#3 | |
Rep Power: 10 |
thank you for the reply. Anyway I forget to specify that this error appears after I used extrudeMesh. |
May 8, 2016, 11:05 |
Rep Power: 15 |
How many cells are there in the direction of extrusion? If it is not 1, then you will not be able to run a 2D problem and I suppose the issue of non-empty directions and edges would be present. Cheers, Antimony |
May 8, 2016, 11:47 |
Hassan Kassem
Rep Power: 17 |
I checked your case again and it works fine with the extrudeMeshDict which is already included. |
May 9, 2016, 03:33 |
#6 | |
Rep Power: 10 |
I tried again and now it works. I don't know why earlier I have this error, probably I checked all the time step and it detects this error. Thank you for the reply |
April 5, 2018, 19:50 |
Luís Tiago Ferreira Fernandes
Rep Power: 8 |
Hi all,
I'm having this problem and now I got confused. After snappyhexmesh I run checkmesh and get that error of the number of edges not aligned. But I get for the time steps of 0.001s and 0.002 which are defined by deltaT. So you're saying that the checkmesh that matters is the one for "time = constant" ? And how can i use checkmesh for that time only? Thanks Luís |
OpenFOAM Training Beijing 22-26 Aug 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | May 3, 2016 04:57 |
OpenFOAM v3.0.1 Training, London, Houston, Berlin, Jan-Mar 2016 | cfd.direct | OpenFOAM Announcements from Other Sources | 0 | January 5, 2016 03:18 |
OpenFOAM Aircraft dynamic meshing | shereez234 | OpenFOAM Running, Solving & CFD | 0 | October 25, 2015 14:58 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[blockMesh] CheckMesh error using a tutorial from OpenFOAM 114 with openFOAM 13 | martapajon | OpenFOAM Meshing & Mesh Conversion | 7 | January 21, 2008 12:52 |
