How to set up volume force to drive the flow
Old   June 8, 2016, 06:56
Default How to set up volume force to drive the flow
Tau
shddr110 is on a distinguished road
Hi guys,
I am simulating a 3D turbulent open channel flow in OpenFOAM. I successfully set up the cyclic boundary conditions at inlet and outlet, and I wish to set up a constant volume force (some people also regard it as a constant pressure drop) inside the whole domain to drive the flow.
I checked many forums but only found a "fan" type. With "fan" the pressure would rise in the streamwise direction. But I want a constant pressure drop. Anyone knows how to do that in OpenFOAM?
Much thanks!
Best Regards
shddr110 is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
parallel code samiam1000 SU2 3 March 25, 2013 04:55
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
