[snappyHexMesh] There are two unconnected cubes,but one disappears after using snappyHexMesh |
September 22, 2016, 23:47 |
Xiaoxue Shen
Rep Power: 9 |
I have read some threads about this matter but still have no idea how to fix this problem. In my case, two unconnected cubes are generated when using blockMesh, I want to remove a sphere mesh from one cube,so I use snappyHexMesh, the locationInMesh is set outside the sphere but inside the cube. Then the other cube mesh disappear. I may be wrong but cannot figure out where the problem is. Would anyone help me? Best wishes, Xiaoxue |
September 23, 2016, 09:36 |
Rep Power: 15 |
Using your current approach, you will not be able to retain the second cube as the second cube is "inaccessible" from your current locationInMesh point and will be removed. My suggestion would be that you create each cube in a separate case. For the one with the sphere, run snappyHexMesh. Then use mergeMeshes to bring the two meshes together. Hope this helps. Cheers, Antimony |
September 23, 2016, 09:43 |
#3 | |
Xiaoxue Shen
Rep Power: 9 |
Thanks for your reply, I'll try that. Hope that will work, I have been stuck here for several days Best wishes, Xiaoxue |
mesh disappear, snappyhexmesh |
[snappyHexMesh] Creating multiple unconnected solid elements with snappyHexMesh | Goddi | OpenFOAM Meshing & Mesh Conversion | 1 | May 12, 2019 09:12 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Mesh two unconnected stl-geometries with snappyHexMesh | Harak | OpenFOAM Meshing & Mesh Conversion | 1 | August 12, 2015 02:20 |
[snappyHexMesh] Geometry disappears when using SnappyHexMesh with multiple blocks | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 3 | February 3, 2015 12:19 |
[snappyHexMesh] crash sHM | H25E | OpenFOAM Meshing & Mesh Conversion | 11 | November 10, 2014 11:27 |
