stitchMesh for uncongruent patches (stitch tolerance)
Old   June 18, 2009, 07:38
Default stitchMesh for uncongruent patches (stitch tolerance)
J
beugold is on a distinguished road
I'm currently working with OF 1.5-dev version, the stitchMesh utility is working quite well with congruent pair patches of interfaces.
I have a case in which the 2 meshes should be stitched in the interface boundaries, they are geometrically the same face, but after meshing they look slightly uncoincide due to the different size spacing assigned to the two meshes.
The stitching still works, but the interfaces is no totally removed. It seems to me, the non-coincide areas on the interfaces are remained in the stitched mesh with the same patch names.
The result is shown below.
The question is,
are there other utilities can remove the remained free faces and points? or can we change the tolerance values of stitchMesh to make the interfaces completely go away?
This is the stitchMeshTolerances text file, it would be nice if someone can explain me what are those values exactly in charge of.
//- Point merge tolerance
pointMergeTol 0.2;
//- Edge merge tolerance
edgeMergeTol 0.05;
//- Integral match point adjustment tolerance
integralAdjTol 0.15;
//- Edge intersection master catch fraction
edgeMasterCatchFraction 0.4;
//- Edge end cut-off tolerance
edgeEndCutoffTol 0.0001;
//- Edge intersection co-planar tolerance
edgeCoPlanarTol 0.8;
beugold is offline   Reply With Quote
stitch, tolerance
[blockMesh] StitchMesh on two patches anita OpenFOAM Meshing & Mesh Conversion 31 April 4, 2013 11:51
[mesh manipulation] Using createPatch in place of couplePatches sripplinger OpenFOAM Meshing & Mesh Conversion 8 November 13, 2009 07:14
radiation patches, viewfactors beams Siemens 1 March 12, 2009 07:39
[mesh manipulation] Using stitchMesh for two pairs of patches kati OpenFOAM Meshing & Mesh Conversion 4 May 24, 2006 02:04
