Line 140 make command not found What is the solution
Old   November 12, 2006, 15:25
Default Hi while I try to compile cod
Faroque Hossain
faroque is on a distinguished road
Hi
while I try to compile code with wmake I am getting following error msg.
+ wmake mhdFoam
/home/faroque/OpenFOAM/OpenFOAM-1.3/wmake/wmake: line 140: make: command not found
/home/faroque/OpenFOAM/OpenFOAM-1.3/wmake/wmake: cannot make, file Make/linuxGcc4DPOpt/objectFiles was not created successfully
does anyone have any idea how to solve this problem?
Thanks in advance.
Faroque
faroque is offline   Reply With Quote
Old   November 13, 2006, 04:16
Default Do you have 'make'? I have
Mattijs Janssens
mattijs is on a distinguished road
/usr/bin/make
To compile OpenFOAM you will need a full development installation on your system ('make', 'ld', 'as'). You can usually install these from your operating system disk.
mattijs is offline   Reply With Quote
[OpenFOAM] ParaView command not found joey ParaView 12 January 18, 2021 05:38
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Bash g command not found mamaly60 OpenFOAM Installation 0 October 18, 2007 17:14
Error starting paraFoam line 67 paraview command not found jango OpenFOAM Installation 4 July 19, 2007 01:39
