paraview,need recompile?
Old   June 22, 2009, 08:26
Default paraview,need recompile?
quinton
quinton is on a distinguished road
hi!
I have a problem with paraview.
i have installed openfoam1.5, and with the first example cavity running, the paraFoam tell me you should select "a reader for cavity.OpenFOAM", so i search all around the forum.... then i get the answer: recompile the paraview and vtk.
yes i did , and paraFoam run good!
but yesterday, i found i need openfoam1.5-dev. so, i built the openfoam1.5-dev. then run the first case cavity, oh! the same hints like i first use of1.5 "a reader for cavity.OpenFOAM" should be selected.
MY God! did i need recompile the paraview again?!!@?
then i chanaged the bash script file for the of1.5, the paraFoam run good! and changed to of1.5-dev. "a reader for cavity.OpenFOAM" hint shocks me again!
i think that i need not recompile the paraview , it must be some script files to be modified, may be dirctories etc.....
what should i do?
thanks advance......
Best Regards!
quinton is offline   Reply With Quote
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 06:21
Compiling with exe option maka OpenFOAM Pre-Processing 9 September 16, 2011 18:54
MRFSimpleFoam amp cyclic patches david OpenFOAM Running, Solving & CFD 36 October 21, 2008 21:55
Recompile turbulence model in OpenFoam qtian OpenFOAM Running, Solving & CFD 7 November 26, 2007 15:51
Installation of 13 grtabor OpenFOAM Installation 14 August 24, 2006 12:43
