Laminar vs. Turbulent
Old   August 17, 2009, 11:58
Default Laminar vs. Turbulent
Miro
Miroo is on a distinguished road
Hi guys,
I have a small problem.
I modelled a rectangular channel (b/h=1) and
after running icoFoam the results are like analytic solution.
Now I want to try to run the same geometry with simpleFoam,
my assumption was that the result had to be the same, if the
Re=100 in both cases.
Know somebody what is my mistake?
It is easy now, but for example if in one part of the channel is
laminar flow and in the another is turbulent, ...what I have to do...???
How can I run problem like this?
Thanks
Miroo is offline   Reply With Quote
Old   August 17, 2009, 12:18
Henrik Rusche
henrik is on a distinguished road
Miroo,
yes, you need to know a-priori whether your flow is turbulent or laminar and select appropriate modeling. Transition and re-laminarisation are research topics. There are many models in the literature, but no general answer.
That's the state of the art and a general issue in CFD.
Henrik
henrik is offline   Reply With Quote
Old   August 17, 2009, 18:07
Default Thank you
Miro
Hi Henrik,
your answer was very helpfully
(und noch vor allem so schnell).
Thank you very much
Miro
Laminar doesn't converge; Turbulent models do? Amit FLUENT 11 April 23, 2015 22:55
Laminar field as initial state for turbulent two phase pipe flow kjetil OpenFOAM Running, Solving & CFD 3 July 21, 2009 09:15
[GAMBIT] 3D Boundary Layer Laminar and Turbulent meshing Harald D ANSYS Meshing & Geometry 1 July 7, 2009 06:20
Half laminar and turbulent model trying to solve Andrew Clarke FLUENT 5 May 19, 2008 13:40
modelling laminar and turbulent flow in the same Ol FLUENT 2 November 25, 2005 02:52
