August 17, 2009, 18:09 |
Conversion of tensors
Sven Winkler
Rep Power: 16 |
a lot of Tensors in OpenFOAM are defined as symmetrical Tensors (volSymmTensorField). I need to summate a symmetrical tensor with a antisymmatrical tensor. Since symmetrical Tensors in OF only consist of 6 components (because the other 3 components are the same, because its symmetrical) I need to convert the symmetrical tensor into a full tensor (9 components) before I can summate it with the antisymmetrical tensor (which also consists of 9 components). Is there any function which is able to convert a symmetrical tensor (6 components) into a full tensor (9 components)? Thanks a lot! |
Conversion of Data file to FLUENT | sanjibdsharma | OpenFOAM Post-Processing | 5 | September 9, 2011 06:13 |
[Salome] Conversion of a cylinder with IdeasUnvToFoam | David* | OpenFOAM Meshing & Mesh Conversion | 1 | September 16, 2009 09:36 |
[Commercial meshers] Several problems with the mesh conversion utility when converting the meshes from Gridgen | su_junwei | OpenFOAM Meshing & Mesh Conversion | 2 | July 26, 2008 23:58 |
Mesh conversion from universal ideas format | Nurul Murad | FLUENT | 0 | March 18, 2004 19:28 |
Energy Conversion Systems (Power and Pro.) Tools | Gordan Feric / Engineering Software (EngWare) | Main CFD Forum | 0 | August 26, 2001 23:14 |
