The blocks
Old   August 24, 2009, 06:18
Default The blocks
Miro
Miroo is on a distinguished road
Hi guys,
does anybody know what is important if I want to define blocks in blockMeshDict...
If there is an block with 8 vertices, what is the rule to defining the
vertex numbers:
is hex (0 1 2 3 4 5 6 7) the same like any other order of vertex numbers
for example hex (1 4 6 2 7 0 5)?
It is not the same but what is the rule?
Thanks
Miroo is offline   Reply With Quote
Old   August 24, 2009, 07:26
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
You have to be aware that there is a vertex numbering rule concerning the local coordinate system of the block.
It is described in the User Guide Chapter 5.3:
http://www.opencfd.co.uk/openfoam/do...#x25-1400005.3
The local coordinate system is defined by the order in which the vertices are presented in the block definition according to:
  • the axis origin is the first entry in the block definition, vertex 0 in our example;
  • the direction is described by moving from vertex 0 to vertex 1;
  • the direction is described by moving from vertex 1 to vertex 2;
  • vertices 0, 1, 2, 3 define the plane ;
  • vertex 4 is found by moving from vertex 0 in the direction;
  • vertices 5,6 and 7 are similarly found by moving in the direction from vertices 1,2 and 3 respectively.
Hope this helps!
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 24, 2009, 09:52
Default Hi
Miro
Thank you very much. It will be helpful!
O-grid for cylinder with varying diameter and several blocks lama ANSYS Meshing & Geometry 4 December 21, 2009 08:57
[blockMesh] Problems meshing wedge type blocks Alan OpenFOAM Meshing & Mesh Conversion 0 July 27, 2009 20:05
[ICEM] C Gridding and removing the triangular blocks brissyben ANSYS Meshing & Geometry 8 June 4, 2009 11:13
BEGINNER ICEM edges of splitted blocks guest7777 CFX 2 October 15, 2007 11:30
common blocks of STAR-CD Mari Siemens 2 January 26, 2005 03:21
