Installation
Old   October 1, 2009, 08:42
Default Installation
Samuele Z
samiam1000 is on a distinguished road
Dear all,
I've installed OpenFOAM and the InstallationTest gives me the following output. Is that ok, to you?
Thanks a lot,
Samuele
samiam@einstein:~/OpenFOAM/OpenFOAM-1.6/bin$ foamInstallationTest
Executing /home/samiam/OpenFOAM/OpenFOAM-1.6/bin/foamInstallationTest:
Checking basic setup...
Shell:              bash
Host:               einstein
OS:                 Linux version 2.6.28-15-generic
Checking main OpenFOAM env variables...
Environment_variable Set_to_file_or_directory                Valid      Crit
$WM_PROJECT_INST_DIR /home/samiam/OpenFOAM                    yes       yes
$WM_PROJECT_USER_DIR /home/samiam/OpenFOAM/samiam-1.6         no        no
$WM_THIRD_PARTY_DIR  /home/samiam/OpenFOAM/ThirdParty-1.6     yes       yes
Checking the OpenFOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory                Valid Path Crit
$WM_PROJECT_DIR      /home/samiam/OpenFOAM/OpenFOAM-1.6       yes  yes  yes
$FOAM_APPBIN         ...M-1.6/applications/bin/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_APPBIN    .../OpenFOAM/site/1.6/bin/linuxGccDPOpt  no        no
$FOAM_USER_APPBIN    ...m-1.6/applications/bin/linuxGccDPOpt  no        no
$WM_DIR              /home/samiam/OpenFOAM/OpenFOAM-1.6/wmake  yes  yes  yes
Checking the OpenFOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN         ...nFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt  yes  yes  yes
$FOAM_SITE_LIBBIN    .../OpenFOAM/site/1.6/lib/linuxGccDPOpt  no        no
$FOAM_USER_LIBBIN    ...penFOAM/samiam-1.6/lib/linuxGccDPOpt  no        no
$MPI_ARCH_PATH       ...penmpi-1.3.3/platforms/linuxGccDPOpt  yes  yes  yes
Third party software
Software Version   Location
gcc      4.3.3     ...nFOAM/ThirdParty-1.6/gcc-4.3.3/platforms/linux/bin/gcc
gzip     1.3.12    /bin/gzip
tar      1.20      /bin/tar
icoFoam  1.6       ...AM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/icoFoam
Summary
Base configuration ok.
Critical systems ok.
done.
samiam1000 is offline   Reply With Quote
Old   October 1, 2009, 18:43
akidess's Avatar
Anton Kidess
There's your answer.
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Installation problems indy OpenFOAM Installation 7 April 3, 2009 09:40
64bitrhel5 OF installation instructions mirko OpenFOAM Installation 2 August 12, 2008 18:07
Installation problems shellbell1999 OpenFOAM Installation 9 April 6, 2006 13:29
OpenFOAM installation on SUSE92 problems derath OpenFOAM Installation 1 April 3, 2006 06:44
