Free surface boundary types
Old   December 8, 2009, 13:41
Default Free surface boundary types
Leo Steenson
lvsteenson is on a distinguished road
I am quite new to openfoam and cfd however I have been trying to simulate two phase flow around a block using interfoam (air and water, block half in half).
I can get the mesh generated and the fluids fields set etc however when I solve my liquid seems to drain out the bottom of the domain even though it is a wall.
Could someone tell me the boundary types that I should be using for inlet, outlet and the walls for files such as alpha, p and u? The idea being that I can visualise the wave pattern and calculate the resistance force on the block before moving onto more complex geometries.
I am using openfoam 1.6
Thanks in advance
lvsteenson is offline   Reply With Quote
Old   December 8, 2009, 14:49
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
Give use some more details on your work.
Are you doing 2D or 3D simulations?
Tell us which boundary conditions you have used so far.
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
boundary types, draining domain, free surface flow, interfoam, multiphase
Multiphase flow. Dispersed and free surface model Luis CFX 8 May 29, 2007 18:13
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
boundary condition at free surface vineet FLUENT 2 April 14, 2002 06:13
Equilibrium of a free surface under surface tensio Ryan Main CFD Forum 1 August 7, 2001 16:14
Radial jet with free surface using FIDAP Dr. Ahmed Hassaneen Main CFD Forum 0 October 28, 1999 13:20
