only hexahedra??? Really??
Old   January 27, 2010, 03:40
Default only hexahedra??? Really??
Patrick Wang
foam_noob is on a distinguished road
Hello everyone,
after meshing with snappy, I ran checkMesh to see the quality of the mesh. CheckMesh states that I only have hexahedra. After viewing the mesh in Paraview, I noticed that there are also other types of elements.
Can someone give me a short explanation for this?
Thanks,
Patrick
foam_noob is offline   Reply With Quote
Old   January 27, 2010, 11:29
Robert Langner
Robat is on a distinguished road
Hi Patrick,
you seem to have a quadratic (hexaedral) mesh.
In case of quadratic meshes every edge of a hexaedron is defined by 3 points.
So your elements look different from the ordinary ones and they are a different element type to.
There is a converter utility in OpenFOAM, if you don't like these elements.
Regards,
Robert
Robat is offline   Reply With Quote
Old   January 28, 2010, 02:45
Patrick Wang
Hi Robert,
Can you give me the command for the conversion, quadratic mesh to pure hexahedra mesh? Are there also other mesh converters that change the type of the cells (hexahedra to tetrahedra)?
Thanks for your help.
Patrick
Old   January 28, 2010, 06:20
Robert Langner
I'm sorry Patrick,
I found this utility anywhere in the net but it got lost after a systen crash, so I can't post it.
Anyway I never missed it because ideasUNVToFoam not supports quadratic elements.
Maybe there is a solution the other way around just to prevent these celltypes but I'm not experienced with snappy.
sry,
Robert
Old   January 28, 2010, 06:54
Patrick Wang
No problem, I'll continue looking. Thank you for your help.
Patrick
hexahedra elements & accuracy??????? vijesh joshi Main CFD Forum 4 December 4, 2009 14:37
Geometric calculation for a hexahedra.. shinde.gopal Main CFD Forum 0 September 25, 2009 07:24
hex to tet program or routine... Renato. Main CFD Forum 11 January 18, 2006 17:12
Egyption Pyramid with All HEXA Selina Tracy Main CFD Forum 17 March 30, 2001 04:15
