Setting Convergence criteria for "rhopSonicFoam" instead of end time
Old   March 6, 2010, 04:00
Question Setting Convergence criteria for "rhopSonicFoam" instead of end time
KGN
mecbe2002 is on a distinguished road
Is it possible to set the convergence criteria as 10^-6 (as in Fluent) instead of specifying endTime for solving steady state problems using "rhopSonicFoam".
mecbe2002 is offline   Reply With Quote
Old   March 7, 2010, 04:00
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Originally Posted by mecbe2002 View Post
If you take a look through applications/solvers, you'll see that some solvers do handle a convergence criterion. They typically have these files:
  • convergenceCheck.H
  • initConvergenceCheck.H
But AFAIK rhopSonicFoam is a transient solver and not steady-state, so I don't know what you'd use for a convergence criterion there.
olesen is offline   Reply With Quote
Old   March 7, 2010, 04:24
KGN
Hi olesen,
I know that "rhopSonicFoam" solver is for transient inviscid compressible flow problems. But i want to solve steady state inviscid compressible flow, so is it possible to set convergence criteria.
Only two solvers are available for inviscid compressible flow problems, "rhopSonicFoam" & "rhoSonicFoam".
Regards
mecbe
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
[CFX] How to avoid negative temperatures? rogbrito CFX 3 February 15, 2010 05:59
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
