twoPhaseEulerFoam Simulations of bubble column
Old   June 26, 2014, 02:25
Default twoPhaseEulerFoam Simulations of bubble column
Vishal
vishal3 is on a distinguished road
hello everyone!!!
I am trying to simulate a 2D bubble column (Case: Hills, 1974, Radial Non uniformity of velocity and voidage in the bubble column) with same column dimensions as of Hills. Here I have attached the case files (I cud not upload polymesh folder from constant directory because of high memory. Rest all the files are attached from constant directory.). I have applied setFields for geometry as mentioned in the setFieldDict in folder system. I have simulated this case for Superficial gas velocity (VG) = 19mm/s. I have attached result for Axial Liquid Velocity (U2Mean).
2D Geometry Details:: 0.139(X) x 0.0005(Y) x 1.38(Z).
Mesh is generated in GMSH open source.
Also attached .geo file for mesh.
It has been observed that the magnitude of axial liquid velocity (Z-direction) is maximum in the region where water is not available (refer setFieldDict). How is this possible? Can anybody help me to make it correct?
File Type: txt Hills2DMesh.txt (940 Bytes, 19 views)
vishal3 is offline   Reply With Quote
Old   July 7, 2014, 04:12
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
The governing equations of twoPhaseEulerFoam (momentum equation) are formulated in the phase-intensive form. This leads to non-zero velocities in regions where the corresponding phase is not present, as in your case.
This is discussed in several threads in this forum and it is explained as a consequence of the phase-intensive formulation.
GerhardHolzinger is offline   Reply With Quote
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 06:01
becker bubble column with twoPhaseEulerFoam GerhardHolzinger OpenFOAM Running, Solving & CFD 4 November 25, 2013 01:53
Solving bubble column using twoPhaseEulerFoam vishal3 OpenFOAM Pre-Processing 0 July 11, 2013 06:19
twoPhaseEulerFoam : bubble column modeling chittipo OpenFOAM Running, Solving & CFD 2 June 11, 2012 06:12
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
