How to set correct mass flow rate for lagrangian particles ?
Old   April 19, 2010, 11:40
Default How to set correct mass flow rate for lagrangian particles ?
sankarv
sankarv is on a distinguished road
Dear All
I am using OF 1.6.x
I am running a simulation where a simple nozzle is injecting compressible gas + solid particles jet into an open atmosphere.
I know the mass flow rate of the particles, density of the particles and the particle diameter distribution from the experiments.
I am using the patchInjection option to inject particles from the inlet patch. The code works without a problem
But I am not quite sure how to set the mass flow rate of the particles correctly in the kinematicCloud1Properties file
My simple question is this:
Can anyone please tell me what is the relationship between
parcelsPerSecond, massTotal, volumeflowRate, SOI and duration ?
Please help me
Thanks
Vaidya
sankarv is offline   Reply With Quote
mass flow rate not conserved in turbomachine, interface defined wrong? wildli FLUENT 3 September 15, 2022 12:19
UDF to measure Mass Flow Rate a.lynchy Fluent UDF and Scheme Programming 31 October 4, 2018 14:10
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
How to correctly set the mass flow rate of solid paricles ? sankarv OpenFOAM Running, Solving & CFD 0 April 18, 2010 18:04
Target mass flow rate Saturn FLUENT 0 December 10, 2004 04:18
