cylinder in crossflow...error...pls hlp
Old   May 14, 2010, 09:56
Unhappy cylinder in crossflow...error...pls hlp
Snehal Janwe
snehal is on a distinguished road
Hello everybody,
I am very new OpenFoam user and am trying to simulate vortex shedding of a cylinder in crossflow. As of now I have started the case with simplefoam which solves for first 4 timesteps and then crashes giving the following error:
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam:ILUPreconditioner::calcReciprocalD(Foam::Fi eld<double>&, Foam::lduMatrix const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 Foam:ILUPreconditioner:ILUPreconditioner(Foam: :lduMatrix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#5 Foam::lduMatrix:reconditioner::addasymMatrixCons tructorToTable<Foam:ILUPreconditioner>::New(Foam ::lduMatrix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#6 Foam::lduMatrix:reconditioner::New(Foam::lduMatr ix::solver const&, Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#7 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#8 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam"
#9 main in "/home/stss5/OpenFOAM/OpenFOAM-1.6.x/applications/bin/linux64GccDPOpt/simpleFoam"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 _start at /usr/src/packages/BUILD/glibc-2.10.1/csu/../sysdeps/x86_64/elf/start.S:116
Gleitkomma-Ausnahme
I dont at all understand what this error means. It would be kind enough if you could enlighten me.
Thanks
snehal is offline   Reply With Quote
Heat transfer of a cylinder in crossflow aloha5i Main CFD Forum 6 December 8, 2023 13:26
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
related to crossflow over a cylinder Jibran Haider FLUENT 0 July 9, 2008 00:12
