Multispecies jet flow in a garage, HELP !!
Old   May 25, 2010, 04:36
Question Multispecies jet flow in a garage, HELP !!
Pierre Mathieu is on a distinguished road
Hi everyone,
I want to simulate the injection of Helium into air in a confined space, and I am quite new with OpenFoam.
I used the reactingFoam solver adding the gravity effect (rho*g) to the velocity equation (UEqn.H) but my results are bad : my species are mixing like if there was no buoyancy effects between them...
I want to figure the density effects between the species during the injection.
If someone have some advices to give, I would be grateful.
Thank you !!
Pierre Mathieu is offline   Reply With Quote
Old   May 27, 2010, 11:04
Eelco van Vliet
eelcovv is on a distinguished road
Hi Pierre,
Perhaps you can use something simular as buoyantBoussinesqPisoFoam, which means you only solve one phase (air) and solve helium as a passive scalar A mixing into the room with A=1 at inlet and A=0 at t=0 in the room. Solve the transport of A and add a momentum source to your U equation based on the fraction of helium in air (just a the boussinesq equation). Something like below, but I haven't checked it, so probably needs some adjustments. Goodluck
To solve transport of A (helium fraction)
    volScalarField kappaEff
        "kappaEff",
        turbulence->nu()/Pr + turbulence->nut()/Prt
    fvScalarMatrix AEqn
        fvm::ddt(A)
      + fvm::div(phi, A)
      - fvm::laplacian(kappaEff, A)
    AEqn.relax();
    AEqn.solve();
    rhok = (rho_air-rho_hel)/rho_air*A;
and to solve U
    fvVectorMatrix UEqn
        fvm::ddt(U)
      + fvm::div(phi, U)
      + turbulence->divDevReff(U)
    UEqn.relax();
    if (momentumPredictor)
        solve
            UEqn
            fvc::reconstruct
                    fvc::interpolate(rhok)*(g & mesh.Sf())
                  - fvc::snGrad(p)*mesh.magSf()
eelcovv is offline   Reply With Quote
Old   May 27, 2010, 14:08
Pei-Ying Hsieh
phsieh2005 is on a distinguished road
Have you looked into twoLiquidMixingFoam?
Pei
phsieh2005 is offline   Reply With Quote
Old   May 28, 2010, 10:33
I am actually trying with twoLiquidMixingFoam, I am waiting for the results.
Thanks for the advices Eelco, I wil try this way too!
Pierre
how to simulate jet flow? Benny FLUENT 18 May 12, 2014 10:53
Approximate Numerical modelling of Jet Flow jphastings Main CFD Forum 0 March 22, 2010 09:10
Slot jet in cross flow. Hamdy FLUENT 0 March 5, 2006 04:04
2D Jet Flow Soon CFX 2 August 16, 2005 11:46
