Turbulent premixed combustion error... XiFoam model |
June 21, 2010, 08:57 |
achinta
I am using XiFoam to simulate turbulent premixed combustion. I got the following error. Could somebody help in finding the cause of this error? ************************************************** ******* [0] attempt to use janafThermo<equationOfState> out of temperature range 100 -> 5000; T = -30.7508#0 Foam::error:rintStack(Foam::Ostream&) in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> >::H(double) const in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libbasicThermophysicalModels.so" #3 Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> >::TH(double, double) const in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #4 Foam::hhuMixtureThermo<Foam::homogeneousMixture<Fo am::sutherlandTransport<Foam::specieThermo<Foam::j anafThermo<Foam:erfectGas> > > > >::calculate() in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #5 Foam::hhuMixtureThermo<Foam::homogeneousMixture<Fo am::sutherlandTransport<Foam::specieThermo<Foam::j anafThermo<Foam:erfectGas> > > > >::correct() in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #6 main in "/usr/logau/expsm/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/XiFoam" #7 __libc_start_main in "/lib64/libc.so.6" #8 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/x86_64/elf/start.S:116 [0] [0] [0] From function janafThermo<equationOfState>::checkT(const scalar T) const [0] in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.6/src/thermophysicalModels/specie/lnInclude/janafThermoI.H at line 64. [0] FOAM parallel run aborting [0] -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. ************************************************** ********** Thank you Regards, Achinta |
June 23, 2010, 05:45 |
carlo
unfortunately i cannot help you, but i must ask you an help: i'm trying to modelling a premixed combustion but i'm not able to set the reactant, i've seen that is possible only to set the material, but it can't be the corret way to set the reactant because in this way is impossible to set a mixture.
please if you can, help me |
Combustion model for CAI/HCCI in AVL FIRE | stoodent | Main CFD Forum | 0 | July 19, 2009 18:37 |
The problem of UDF in Non premixed combustion model | zhangyuan | Main CFD Forum | 0 | May 25, 2009 09:41 |
turbulent combustion | palani kumar | FLUENT | 0 | October 15, 2007 14:26 |
How can I model H2-AIR combustion | popi | CFX | 8 | August 16, 2007 05:32 |
Need Similar Combustion Tutorial as my model | Arnab | Siemens | 0 | May 24, 2005 18:23 |
