March 4, 2020, 08:03 |
Question about permeable B.C. for baffle
CHEUNG WING KI
Rep Power: 9 |
Dear foamers,
Greetings, Since I am simulating LPT with porous media(explicitly). The particle will penetrate the porous media because it does not have suitable interaction between particle and porous source term. My goal is to letting the particle rebounds from the porous but "permeable", more clearly, identical with internal faces. Therefore I created a baffle which surrounds the porous source hence I can specify patchInteraction. However, I am not sure which B.C. type is suitable for this baffle in p, U, Yi field? Thanks in advance, Rick |
[ICEM] setting B.C & FF shape for high A.O.A. | jyh3134 | ANSYS Meshing & Geometry | 5 | August 7, 2013 03:23 |
Question) fan simulation & B.C | Serazio | FLUENT | 0 | February 7, 2011 13:27 |
Urgent! Help on UDF to set B.C. of 3rd type | Ray Hong | FLUENT | 0 | December 28, 2005 19:35 |
How to set B.C. of the 2nd or 3rd type in UDS? | Ray Hong | FLUENT | 0 | December 28, 2005 06:03 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
