Lift&Drag Coefficients is not accurate enough!
Old   August 5, 2010, 09:41
Default Lift&Drag Coefficients is not accurate enough!
Rasoul
aut_iut is on a distinguished road
Dear Foamers,
I'm working on a fixed/moving cylinder case. I used icoFoam solver for Re<300 and results are acceptable.
When Re exceed from 300 the drag coefficients become different from literature data. I'm using pisoFoam (with LES or RAS turbulence models) solver. For example for Re=500, experimental results say that avaraged drag coefficient should be 1.18, while OpenFoam calculates it in the range of 1.35-1.5 (depending on the changing parameters like BC and initial conditions).
I supposed maybe it is because of 3D effect. So I implemented the simulation for a 3D case. But still there is a considerable difference between my results and papers one.
I'm wondering if one could suggest me how to fix this problem.
Isn't it solver errors? To be honest I'm thinking about the accuracy of pisoFoam solver.
Regards,
Rasoul
aut_iut is offline   Reply With Quote
Old   August 5, 2010, 10:05
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
and grid dependency?
niklas is offline   Reply With Quote
Old   August 5, 2010, 10:13
Rasoul
Yes, of course!
My initial grid is fine and refining the mesh just increases the solution time without any considerable improve to results.
I also changed the divScheme in fvScheme file.
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 11:26
implementation of diffusion coefficients and use of diffusion coefficients stephan OpenFOAM Running, Solving & CFD 0 February 28, 2010 14:30
Computing aerodynamic coefficients on bidimensional sections in 3D problems Aragon FLUENT 0 July 22, 2009 04:07
how to get more accurate accurate coefficient of aerodynamic of subsonic airfoil nuimlabib Main CFD Forum 3 July 4, 2009 10:17
Time accurate? Steve Main CFD Forum 2 March 25, 2008 08:39
