Boundary Conditions RANS rhopisofoam
Old   August 2, 2010, 06:24
Default Boundary Conditions RANS rhopisofoam
Jotazeld is on a distinguished road
Dear CFD friends,
I am very new to OpenFoam. I would like to initialize alphat, epsilon, k mut, omega and R for rhopisofoam RANS. Could someone help me please?,
Thank you very much.
Jotazeld is offline   Reply With Quote
Old   August 22, 2010, 08:13
Nilesh Rane
nileshjrane is on a distinguished road
Can you please post details about your case and what kinda help you need?? i mean in calculating or setting up or whatever..
Imagination is more important than knowledge..
nileshjrane is offline   Reply With Quote
Old   August 22, 2010, 13:46
Dear CFD friend,
I have a duct ( inlet, outlet, walls) and the velocity at the inlet is 10 m/s and the pressure at the outlet is 0.
If you need more information I can tell you more.
Old   August 22, 2010, 15:18
Nilesh Rane
Well, i am also not very much sure about this, as i am also facing same problems, but would like to tell you what i know. It might help you nevertheless.
alphat =turbulent thermal diffusivity
R= Reynolds stress tensor
eps = turbulent dissipation rate
omega = specific turbulent dissipation rate
k = turbulent kinetic energy
I think the variables you need to specify depend upon the turbulence model you use. Say you are using k-eps model then you will need to specify k and epsilon and alphat.
And in case you need to calculate the actual values for the parameters, you can use the formulas used widely. See following link:
http://jullio.pe.kr/fluent6.1/help/html/ug/node178.htm
I dont know about specifying values for alphat and R.
Hope this helps.
just got some more info :-)
Please see this post, you will get more info:
http://www.cfd-online.com/Forums/openfoam-solving/79323-solver-subsonic-compressible-turbulent-flow-1-7-a.html#post272288
Last edited by nileshjrane; August 22, 2010 at 15:22. Reason: just got some more info :-)
Old   August 22, 2010, 16:34
Smile
Thank you very much !!!.
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 07:21
Pressure boundary conditions Lionel S. Main CFD Forum 1 August 24, 2007 18:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 04:15
Copying boundary conditions from model to model Lior FLUENT 3 September 23, 2004 16:10
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 19:23
