setup of inital condition
Old   September 9, 2010, 06:55
Default setup of inital condition
Silvia Di Francesco
gija79 is on a distinguished road
hi
I would like to simulate an unsteady flow with a linear thermal gradient (with the vertical depth Z) at inlet.
The all dominion should be initialized with the same gradient.
How can I impose these value of temperature to the internal mesh? the simplified problem is something like the image attached.
Suggestion about the solver to use?
Thanks Silvia
gija79 is offline   Reply With Quote
Old   September 10, 2010, 12:14
edison
Edison_Ge is on a distinguished road
You may need to do some modification on the source code for new inlet boundary. http://www.tfd.chalmers.se/~hani/kur...yCondition.pdf
This pdf may help you find a way.
Edison_Ge is offline   Reply With Quote
Old   September 10, 2010, 12:25
edison
actually, it may be easier that. Take a look at the discussion http://www.cfd-online.com/Forums/ope...-openfoam.html
and then check the user guide 4.2.9. Hope it may help.
Old   September 10, 2010, 13:52
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Did you try funkySetFields?
Bye.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   September 23, 2010, 12:30
Default bouyantboussinesqpimpleFoam
Silvia Di Francesco
thanks for the suggestions. I used funkysetfields for temperature gradient and
timeVaryingUniformFixedValue for unsteady conditions at inlet.
The fluid to simlate to is water, so uncompressible
About the solver:
I tried to use bouyantboussinesqpimpleFoam putting the following boundary conditions:
U
internalField uniform (0 0 0);
boundaryField
inlet : timeVaryingUniformFixedValue;
outlet: zeroGradient;
bottom fixed value uniform (0 0 0);
atmosphere zeroGradient;
defaultFaces empty (2D case)
T
inlet
type fixedValue;
value nonuniform
All other boundaries are set as zerogradient.
p
inlet
type zeroGradient;
outlet
type fixedValue;
value uniform 0;
bottom
type zeroGradient;
atmosphere
type fixedValue;
value uniform 0;
defaultFaces
type empty;
For thermopysical aspect I use the folowing:
thermoType hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<icoPolynomial>>>>>;
mixture water 1 18 4190 0 1.001e-03 10;
pRef 100000;
I tried with and without gravity but the temperature field seems to become crazy, with value too high!
Did I make some big mistake or should I consider a different solver?
and which one?
thank you
Silvia
[ICEM] Hexa mesh, curve mesh setup, bunching law Anorky ANSYS Meshing & Geometry 4 November 12, 2014 00:27
How to setup boundary condition with couple solver JINHUI FLUENT 0 September 8, 2006 17:07
Boundary Condition Setup Lee Main CFD Forum 1 September 8, 2004 22:10
how to setup boundary condition young Main CFD Forum 4 April 11, 2004 19:57
Please, how to setup different initial condition. RAN FLUENT 1 November 8, 2002 08:51
