How can i plot variables over time?
Like Tree1Likes
  • 1 Post By maysmech
Old   August 30, 2010, 04:30
Lightbulb How can i plot variables over time?
maysmech's Avatar
maysmech is on a distinguished road
Dear Foamers,
I want plot velocity (U mean, fluctuation and U) over time in the case which is solved with pisoFoam.
How can i do this in paraView? when i choose plot global variable over time none of variables are available to select for y direction.
maysmech is offline   Reply With Quote
Old   August 30, 2010, 06:31
yvin
camille.yvin is on a distinguished road
I think the best is to use the sampleDict to extract data over times and write a script to bring all the informations in one file. After that, plotting is easy with gnuplot.
camille.yvin is offline   Reply With Quote
Old   August 30, 2010, 09:34
maysmech's Avatar
Thanks for your reply,
if i understand your meaning, i should make a sampleDict file in system folder.
but i have run my case now and i want using paraView software. your suggestion seems good but need to run the case again.
is there another way to plot a variable of one point versus time?
Bashar likes this.
Old   August 30, 2010, 09:35
Chris Sideroff
cnsidero is on a distinguished road
You might want to check out pyFoam: http://openfoamwiki.net/index.php/Contrib_PyFoam .
There's one specifically for what you're asking for: http://openfoamwiki.net/index.php/Co...mSamplePlot.py
cnsidero is offline   Reply With Quote
Old   September 1, 2010, 11:19
yvin
You can use a sample Dict after a simulation. Juste use "sample" instead of "pisoFoam"
Old   September 17, 2010, 01:01
Alberto Passalacqua
Also, paraview can do that.
Alberto Passalacqua
Old   September 17, 2010, 06:08
maysmech's Avatar
how can paraview do it?
Old   September 17, 2010, 10:33
Alberto Passalacqua
There is a filter called "Plot selection over time"
Alberto Passalacqua
Old   September 22, 2010, 22:20
paka is on a distinguished road
http://www.openfoam.com/docs/user/sample.php
paka is offline   Reply With Quote
[OpenFOAM] How to plot flow rate over time with Paraview sekunda ParaView 17 July 23, 2020 13:14
PostChannel maka OpenFOAM Post-Processing 5 July 22, 2009 09:15
how to plot a variable with respect to time nandiganavishal OpenFOAM Running, Solving & CFD 0 March 15, 2009 20:02
choosing a time frame to present a plot AAA FLUENT 1 July 29, 2007 18:41
flow time plot units alex FLUENT 0 July 2, 2007 13:38
