How to get steady result in pitzDaily using LES model |
October 15, 2018, 05:19 |
Yuan Jiahui
Rep Power: 7 |
Hi Foamers,
I am trying to use simpleFoam to solve pitzDaily with LES model and compare the results between LES model and RAS model (k-epsilon model). And I change part codes in tutorials(incompressibel/pisoFoam/les/pitzDaily), but the caculation is not convergent no matter how long the running time I set. Here is my changes: 1.fvsolution solvers { p { solver GAMG; tolerance 1e-06; relTol 0.1; smoother GaussSeidel; } pFinal { $p; smoother DICGaussSeidel; tolerance 1e-06; relTol 0; } "(U|k|B|nuTilda|s)" { solver smoothSolver; smoother GaussSeidel; tolerance 1e-05; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 0; consistent yes; residualControl { p 1e-2; "(pFinal|U|B|nuTilda|s)" 1e-3; } } relaxationFactors { equations { U 0.9; // 0.9 is more stable but 0.95 more convergent ".*" 0.9; // 0.9 is more stable but 0.95 more convergent } } 2.conrtolDict application simpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 2000; deltaT 1; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Please tell why I can not get steady result in LES model Best regards, yuanjiahui |
October 16, 2018, 05:01 |
Robert
Rep Power: 11 |
Do your calculations with a transient solver like pisoFoam or pimpleFoam. Then compare similar time steps.
If you liked my answer to your question, please consider leaving a "Like" in return |
October 16, 2018, 07:05 |
Rep Power: 12 |
You have to use a transient solver for LES but for comparison with RAS results, you can add "fieldAverage" function within controlDict for getting the mean values of U and p.
October 16, 2018, 07:48 |
Yuan Jiahui
Rep Power: 7 |
Hi mzzmrt.Can I get a steady result with a transient solver like pisoFoam in LES model?
October 16, 2018, 07:57 |
Yuan Jiahui
Rep Power: 7 |
Hi RobertHB. I intended to caculate with simpleFoam, but then I found that LES model does not work with simpleFoam. So can I get steady result with pisoFoam in LES model and compare it with RANS model?
October 16, 2018, 08:36 |
Robert
Rep Power: 11 |
In short, no. pisoFoam calculates a transient, time dependant solution. And you use LES to resolve the transient flow without averaging like RAS does.
If you want a steady, time independant, solution use simpleFoam and a RAS model. If you want to compare LES and RAS, you can do so by comparing the steady RAS and the transient RAS and LES results.
October 16, 2018, 08:57 |
#7 | |
Yuan Jiahui
Rep Power: 7 |
regards |
October 16, 2018, 09:20 |
#8 | |
Robert
Rep Power: 11 |
Conduct both for the same runtime.
October 16, 2018, 13:02 |
#9 |
Rep Power: 12 |
Add this to your controlDict, solve LES with pisoFoam and check the results in paraview:
functions { fieldAverage1 { type fieldAverage; functionObjectLibs ("libfieldFunctionObjects.so"); enabled true; outputControl outputTime; fields ( U { mean on; prime2Mean off; base time; } p { mean on; prime2Mean off; base time; } ); } } |
October 16, 2018, 20:37 |
#10 |
Yuan Jiahui
Rep Power: 7 |
October 17, 2018, 03:06 |
#11 |
Robert
Rep Power: 11 |
Compare whatever you want, but notice that LES is a transient turbulence simulation, not steady. So either compare different timesteps to your steady solution or use a long runtime and the average approach suggested by mzzmrt. You can also use the "Temporal Statistics" filter of paraview to get an average over the total runtime.
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
SpalartAllarmasIDDES LES model | mmmn036 | OpenFOAM Running, Solving & CFD | 1 | April 23, 2014 20:01 |
Virtual inheritance problem while adding public member function to LES SGS Model | konneym | OpenFOAM Programming & Development | 4 | November 4, 2013 11:37 |
OpenFOAM: LES turbulence model names | Ollie | OpenFOAM | 5 | January 7, 2013 10:24 |
OpenFOAM: LES turbulence model names | Ollie | Main CFD Forum | 1 | April 11, 2011 13:03 |
