Mesh conversion from fluent
Old   October 15, 2010, 05:57
Default Mesh conversion from fluent
alessio.nz's Avatar
Alex
alessio.nz is on a distinguished road
Hi everyone,
I tried to convert mesh from fluent with the command "fluentMeshToFoam <filename>" and at first it was not working.
After that, I created a new case file, for instance I copied the Pitzdaily3d case and I renamed it. In the new case folder I tried with the command mentioned and I had the mesh without any error. I also checked the mesh with "paraFoam" and everything was correct.
What about the blockMeshDict? why is it not there? could you please tell me how to solve the problem?
regards, Alex
alessio.nz is offline   Reply With Quote
Old   October 15, 2010, 06:05
Masashi Ohbuchi
Ohbuchi is on a distinguished road
The fluentMeshToFoam needs only system/controlDict and doesn't need blockMeshDict.
Ohbuchi is offline   Reply With Quote
Old   October 15, 2010, 06:09
alessio.nz's Avatar
Alex
Hi do you mean I should modify the controlDict file for the new mesh or is it enough with what I have?
Old   October 15, 2010, 15:17
Masashi Ohbuchi
You don't need modify controlDict.
fluentMeshToFoam doesn't check inside the file.
Old   October 17, 2010, 08:31
maysmech's Avatar
maysmech is on a distinguished road
regards, Alex
hi,
you don't need blockMeshDict file. when you import mesh from other softwares after the import you don't need type blockMesh because your mesh is ready for processing. so you should revise boundaries in 0 folder same as your patches in constant/polyMesh/boundary file and then type your solver for example pisoFoam ...
Best,
maysmech is offline   Reply With Quote
Old   October 18, 2010, 05:34
alessio.nz's Avatar
Alex
Hi thanks for the hint. Actually I am new with OF structure. In order to convert the mesh I made a new case file simply copying a present one (for instance pitzdaily3d of XiFoam) and I converted the mesh (which was with its BC already done). Is that the right way?
Old   October 18, 2010, 06:27
Default Example
alessio.nz's Avatar
Alex
if this is my boundary file (costant/polymesh/) for the mesh I converted:
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
9
wall
type wall;
nFaces 2126;
startFace 1564642;
inlet
type patch;
nFaces 3862;
startFace 1566768;
wall-swirl-plate
type wall;
nFaces 7408;
startFace 1570630;
wall-outflow-dump
type wall;
nFaces 1600;
startFace 1578038;
wall-chamber
type wall;
nFaces 3200;
startFace 1579638;
wall-dump
type wall;
nFaces 4400;
startFace 1582838;
wall-inflow
type wall;
nFaces 9328;
startFace 1587238;
wall-outflow
type wall;
nFaces 1600;
startFace 1596566;
outlet
type patch;
nFaces 4400;
startFace 1598166;
If I want to change the files contained in the system/0/ folder, could you suggest me an example? For example using the Pitzdaily3D?
regards
Old   October 18, 2010, 09:27
maysmech's Avatar
Compare these 9 patches with 0/P and 0/U. you should have 9 patch with these names and their types. same as pitzDaily case. i recommend you to read user guide of OpenFOAM. you can see available boundary condition and its structure.
Old   October 18, 2010, 15:12
Default re:
alessio.nz's Avatar
Alex
many thanks, I will let you know!
Gambit problems Althea FLUENT 22 January 4, 2017 03:19
[ICEM] Using Surface Mesh from ANSA for Fluent Sim tommymoose ANSYS Meshing & Geometry 15 March 3, 2016 17:29
[Commercial meshers] Fluent Mesh (XP32) to OpenFoam archymedes OpenFOAM Meshing & Mesh Conversion 1 April 1, 2010 05:26
[Commercial meshers] Wrong face orientations after conversion from fluent mesh stevecollie OpenFOAM Meshing & Mesh Conversion 6 July 14, 2008 07:20
Import ICEM Mesh to Fluent Fluent Beginner FLUENT 5 June 23, 2004 00:27
