Heat generation at the mixing plane interface |
January 17, 2019, 14:37 |
Enrico De Filippi
Rep Power: 7 |
Hi, I'm simulating an axial turbine using steadyUniversalMRFFoam, and the results show a heat generation in the rotor domain, and consequently the temperature is not conserved. Do you have a reason for this strange behavior? I've used the rotalphy jump at the mixing plane interface, as necessary for the rotalphy eqaution.
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Mixing Problem in Double Pipe Heat Exchanger With Fluid Fluid Interface | Shomaz ul Haq | CFX | 3 | December 17, 2015 12:50 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Meshing a Mixing Plane using ICEM | Will Anderson | FLUENT | 0 | November 6, 2010 17:08 |
