Time Averaging in OpenFoam
Like Tree1Likes
  • 1 Post By Tarak
Old   November 1, 2010, 14:14
Default Time Averaging in OpenFoam
Tarak
Tarak is on a distinguished road
Hii,,
Can someone please tell how to get time averaged velocity, pressure field in LES in OpenFoam.
Thaning You,
Tarak
Tarak is offline   Reply With Quote
Old   November 2, 2010, 02:17
Karl-Johan Nogenmyr
kalle is on a distinguished road
Hi!
Have a look at the pitzDaily tutorial (OF 1.6):
tutorials/combustion/XiFoam/les/pitzDaily
and check how the system/controlDict is written...
Good luck!
kalle is offline   Reply With Quote
Old   November 2, 2010, 15:39
Tarak
Hii,
Thanks for the reply. I went through the code and in fieldAverage.H i'm pasting some lines from it:
00039 // Whether to perform a clean restart, or start from previous
00040 // averaging info if available
00041 cleanRestart true;
00042
00043 // Whether to reset the averaged fields after they have been written.
00044 // Used to average over only the preceding write interval for transient
00045 // cases.
00046 resetOnOutput true;
And these lines are not present in controlDict of my case directory. So can I be sure
that even if I get the solution after multiple runs (i.e restarting in between),
I would be getting the correct time averaged fields?
Thanks,
Tarak
Old   November 2, 2010, 16:11
Tarak
Hii,
I have one more doubt. The problem is that I want to do the time averaging for the fields only for the solutions after it has reached a kind of statistically stationary state. So, I need to ignore the field values of the intial times while calculating the the average.
Can you please offer me a solution for this?
Thanks,
Tarak
Old   November 2, 2010, 16:28
Tarak
Hii,
I think I have a solution to my last post. I need to turn off the option of fieldaveraging in controlDict for the initial time steps, and turn it on (by editing controlDict and restarting) from the moment I want the fields to be averaged. Please comment on this as well as my 2nd post.
Thanks,
Tarak
Alhasan likes this.
Old   November 3, 2010, 02:15
Karl-Johan Nogenmyr
Correct. Don't use the lines in your controlDict until you are ready to start sampling.
2nd post: If you leave your controlDict as it is and leave the UMean, pMean, etc. files in the time directory, they will be read in when you restart.... You can track the number of samples collected in a file found in the /uniform directory located in each time directory.
Good luck!
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
If OpenFOAM can run different solver in different domain in the same time ? panda60 OpenFOAM Running, Solving & CFD 4 May 15, 2014 10:07
Time averaging results from a transient run Flow Squad CFX 4 October 24, 2011 09:11
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
export time steps for ensemble averaging Thomas Baumann Siemens 0 March 2, 2010 03:19
